[QGIS-Developer] OSGeo4w 32 or 64 bit
Paul Burns paulburns at simplexity.com.au
Mon Sep 5 17:31:02 PDT 2022
Hi
I am attempting to build QGIS for windows and have been using a QtCreator 64 bit compiler.
Section 4.1.2 Other tool…. of
https://github.com/qgis/QGIS/blob/master/INSTALL.md
Has a link to 64 bit OSGeo4w, but it returns a 404 Not found.
I note on https://trac.osgeo.org/osgeo4w/ the OSGeo4W network installer, does not specify if it is 32 or 64 bit?
Are the packages I have downloaded using the OSGeo4W network installer 32 bit, and therefore I will need to compile QGIS as 32 bit?
Thanks for your help.
Paul
More information about the QGIS-Developer mailing list
