[QGIS-Developer] Re-add Georeferencer action to raster menu?
Nyall Dawson nyall.dawson at gmail.com
Mon Sep 26 23:40:17 PDT 2022
Hi devs!
I'm after some wider feedback -- in 3.26 I moved the "Georeferencer"
action from the Raster menu to the "Layers" menu, as the georeferencer
was expanded to support more than just raster layers and it no longer
seemed a logical place to put this action.
But we've seen a lot of confusion and bug reports about the missing
action since this move.
I'm pondering whether we should add a second shortcut to the
georeferncer back into the Raster menu, so that this tool will be
available through either location.
Is this a good idea and helps avoid user confusion? Or a bad one which
causes more UI bloat?
Nyall
More information about the QGIS-Developer mailing list
