[QGIS-Developer] Re-add Georeferencer action to raster menu?
Andreas Neumann a.neumann at carto.net
Mon Sep 26 23:51:07 PDT 2022
Hi Nyall,
Thanks for raising this. Initially I was also confused, but the new menu
position makes more sense.
I would be -1 on adding it also to the raster menu. If we do add it to
the "Raster" menu, as a consequence, it would also have to be added to
the "Vector" menu ...
It just needs a bit of time for people to get used to the new menu
position in the "Layers" menu, I think.
Andreas
On 2022-09-27 08:40, Nyall Dawson via QGIS-Developer wrote:
> Hi devs!
> I'm after some wider feedback -- in 3.26 I moved the "Georeferencer"
> action from the Raster menu to the "Layers" menu, as the georeferencer
> was expanded to support more than just raster layers and it no longer
> seemed a logical place to put this action.
> But we've seen a lot of confusion and bug reports about the missing
> action since this move.
> I'm pondering whether we should add a second shortcut to the
> georeferncer back into the Raster menu, so that this tool will be
> available through either location.
> Is this a good idea and helps avoid user confusion? Or a bad one which
> causes more UI bloat?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220927/4c3bb018/attachment.htm>
More information about the QGIS-Developer mailing list
