[QGIS-Developer] Temporarily disable map canvas right click showing Copy Coordinates
Jacky Volpes
jacky.volpes at oslandia.com
Thu Apr 13 06:13:54 PDT 2023
Maybe return True in your eventFilter, so that the event is not
processed further by other widgets?
Regards,
Jacky Volpes
Ingénieur SIG - Oslandia
Le 13/04/2023 à 08:11, Catania, Luke A ERDC-RDE-GRL-VA CIV via
QGIS-Developer a écrit :
> I thought I tried this before and it still showed the menu with its menu grayed out, but maybe I set it on the submenu item, but I solved my issue by calling
> menu.setDisabled(True) on the QMenu. I reset it to False after my editing is done so the context menu is available again.
> If anyone thinks of a better way feel free to answer, but this will work for now. I was hoping the setContextMenuPolicy methd would work.
> -----Original Message-----
> From: QGIS-Developer<qgis-developer-bounces at lists.osgeo.org> On Behalf Of Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer
> Sent: Thursday, April 13, 2023 1:29 AM
> To: Nyall Dawson<nyall.dawson at gmail.com>
> Cc:qgis-developer at lists.osgeo.org
> Subject: Re: [QGIS-Developer] Temporarily disable map canvas right click showing Copy Coordinates
> I am not using QgsMapTool.
> T o capute mouse events, I declared my class as
> class AoiSizeValidator(QWidget):
> And added
> def eventFilter(self, source, event):
> with code that captures mouse click events.
> I tried using
> iface.mapCanvas().setContextMenuPolicy(Qt.NoContextMenu)
> and
> iface.mapCanvas().setContextMenuPolicy(Qt.PreventContextMenu)
> But it did not work. I found that suggestion on a site where someone was looking to disable the context menu for QWebEngineView, so thought it would work for the map canvas.
> I did find half a solution by setting
> iface.mapCanvas().contextMenuAboutToShow.connect(self.disable_context_menu)
> def disable_map_canvas_context_menu(self, menu: QMenu, event: QgsMapMouseEvent):
> menu.clear()
> which basically completely clears the context menu from all its widgets, but I would like he menu back after my right click event happens to end the edit session.
> From: Nyall Dawson<nyall.dawson at gmail.com>
> Sent: Wednesday, April 12, 2023 9:09 PM
> To: Catania, Luke A ERDC-RDE-GRL-VA CIV<Luke.A.Catania at erdc.dren.mil>
> On Thu, 13 Apr 2023 at 10:47, Catania, Luke A ERDC-RDE-GRL-VA CIV via QGIS-Developer<qgis-developer at lists.osgeo.org> wrote:
>> I have an event filter on the map canvas that performs a commit during feature editing when right clicking on the canvas. While this performs the commit, it then pops up Copy Coordinates. I don’t want the user to see this. I want my mouse click event to be recognized and not have QGIS use it to popup the Copy Coordinates. Is there a way to call QgsMapTool.deactivate on that built in tool just for this instance and then reactivate it?
> Are you using a custom QgsMapTool subclass? If so, implement the "flags" method and don't return the ShowContextMenu flag.
> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info:
>> Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
>> Unsubscribe:
> List info: Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
> Unsubscribe: Blockedhttps://lists.osgeo.org/mailman/listinfo/qgis-developerBlocked
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230413/c1ef3954/attachment.htm>
