[QGIS-Developer] [EXTERNAL] Re: Outdated WebKit engine version in QGIS
Nguyen, Huy Minh
huyminh.nguyen at here.com
Tue Apr 18 23:55:22 PDT 2023
If Qt Webengine is in QGIS why it cannot be used ? Is there maybe any Qgs class that uses Qt Webengine internally and can be reused ?
Minh
-----Original Message-----
Sent: Wednesday, April 19, 2023 7:28 AM
To: Nguyen, Huy Minh <huyminh.nguyen at here.com>
Cc: qgis-developer at lists.osgeo.org
Subject: [EXTERNAL] Re: [QGIS-Developer] Outdated WebKit engine version in QGIS
On Wed, 19 Apr 2023 at 15:24, Nguyen, Huy Minh via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> Hi,
> I have been using WebKit engine from the PyQt library built in QGIS 3.30 when developing QGIS plugin in Python to load web pages directly in QGIS. The Webkit engine used seems to be very outdated and not possible to render modern web pages. For example, the engine used in QGIS 3.30 dated back to 2016: AppleWebKit/602.1 (KHTML, like Gecko) QGIS3 Version/10.0 Safari/602.1.
> Is there any chance to update the built-in Webkit engine version in next release of QGIS ?
> Otherwise, can the WebKit engine be updated locally and provided to the application ?
> Does QGIS offer any other built-in alternatives, like the Qt WebEngine or other web engine with python bindings ?
It's an extremely messy and painful situation, but ultimately the answer is NO. There's no alternative, no way of updating the webkit version used by QtWebkit, and Qt Webengine CANNOT be used as it stands in QGIS.
Nyall
> Thank you,
> Minh
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:
> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flist
> s.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-developer&data=05%7C01%7Chuymi
> nh.nguyen%40here.com%7C83865261759a4e94b02808db4096e273%7C6d4034cd7225
> 4f72b85391feaea64919%7C0%7C0%7C638174789008955324%7CUnknown%7CTWFpbGZs
> b3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D
> %7C3000%7C%7C%7C&sdata=zsajlNbGjcZdZMAp%2BnBCgSAP1Tap5O6Ni8WbFSvKsuE%3
> D&reserved=0
> Unsubscribe:
> D&reserved=0
LEARN FAST: This email originated outside of HERE.
Please do not click on links or open attachments unless you recognize the sender and know the content is safe. Thank you.
