[QGIS-Developer] [EXTERNAL] Re: Outdated WebKit engine version in QGIS
Nyall Dawson nyall.dawson at gmail.com
Wed Apr 19 15:29:52 PDT 2023
On Wed, 19 Apr 2023 at 16:55, Nguyen, Huy Minh <huyminh.nguyen at here.com> wrote:
> Hi,
> If Qt Webengine is in QGIS why it cannot be used ? Is there maybe any Qgs class that uses Qt Webengine internally and can be reused ?
It's not in QGIS. It's in Qt, but can't be used from QGIS. QtWebengine
requires some initialization steps before construction of the
QApplication used by QGIS, and unfortunately these steps introduce an
incompatibility in OpenGL handling which breaks the QGIS 3D
functionality.
Pending an upstream Qt / Webengine fix we can't resolve this
situation, and Qt Webengine is not a possibility for use in QGIS.
Nyall
> Minh
> -----Original Message-----
> From: Nyall Dawson <nyall.dawson at gmail.com>
> Sent: Wednesday, April 19, 2023 7:28 AM
> To: Nguyen, Huy Minh <huyminh.nguyen at here.com>
> Cc: qgis-developer at lists.osgeo.org
> Subject: [EXTERNAL] Re: [QGIS-Developer] Outdated WebKit engine version in QGIS
> On Wed, 19 Apr 2023 at 15:24, Nguyen, Huy Minh via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> > Hi,
> > I have been using WebKit engine from the PyQt library built in QGIS 3.30 when developing QGIS plugin in Python to load web pages directly in QGIS. The Webkit engine used seems to be very outdated and not possible to render modern web pages. For example, the engine used in QGIS 3.30 dated back to 2016: AppleWebKit/602.1 (KHTML, like Gecko) QGIS3 Version/10.0 Safari/602.1.
> > Is there any chance to update the built-in Webkit engine version in next release of QGIS ?
> > Otherwise, can the WebKit engine be updated locally and provided to the application ?
> > Does QGIS offer any other built-in alternatives, like the Qt WebEngine or other web engine with python bindings ?
> It's an extremely messy and painful situation, but ultimately the answer is NO. There's no alternative, no way of updating the webkit version used by QtWebkit, and Qt Webengine CANNOT be used as it stands in QGIS.
> Nyall
> > Thank you,
> > Minh
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info:
> > https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Flist
> > s.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-developer&data=05%7C01%7Chuymi
> > nh.nguyen%40here.com%7C83865261759a4e94b02808db4096e273%7C6d4034cd7225
> > 4f72b85391feaea64919%7C0%7C0%7C638174789008955324%7CUnknown%7CTWFpbGZs
> > b3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D
> > %7C3000%7C%7C%7C&sdata=zsajlNbGjcZdZMAp%2BnBCgSAP1Tap5O6Ni8WbFSvKsuE%3
> > D&reserved=0
> > Unsubscribe:
> > D&reserved=0
> LEARN FAST: This email originated outside of HERE.
> Please do not click on links or open attachments unless you recognize the sender and know the content is safe. Thank you.
More information about the QGIS-Developer mailing list
