[QGIS-Developer] PSA: Don't update to Gnome 44!
Richard Duivenvoorde rdmailings at duif.net
Thu Apr 27 22:42:21 PDT 2023
Ooh, tricky! Thanks Nyall for this heads up!
Was 44 already released actually?
As Debian testing/sid is now in something-freeze (and on 43).. I do not think it will enter 44 before release of Bookworm..?
So at least Debianista's are good untill that.
Reading the issue, I see it's about Qt5 AND Qt6, and there seems to be some work-around running applications in native Wayland mode (but in that QGIS has other issues...)
Hope this will be fixed soon...
Regards,
Richard
On 4/28/23 07:25, Nyall Dawson via QGIS-Developer wrote:
> Hi lists,
> Just a quick PSA: If you're using QGIS (or any Qt based app), I recommend avoiding an upgrade to any gnome 44 based distribution for now.
> You'll get hit with this nasty bug: https://gitlab.gnome.org/GNOME/mutter/-/issues/2715 <https://gitlab.gnome.org/GNOME/mutter/-/issues/2715> which breaks drag and drop functionality in all Qt applications. And in the process, basically makes QGIS unusable... 😱
> You've been warned!
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
