[QGIS-Developer] Pyqgis master api search broken?
Delaz J delazj at gmail.com
Wed Feb 8 01:31:26 PST 2023
Probably related to
https://github.com/readthedocs/sphinx_rtd_theme/issues/1420
Need to check what version we are running...
Harrissou
Le 08/02/2023 à 10:12, Johannes Kröger (WhereGroup) via QGIS-Developer a
écrit :
> Broken for me as well, I tested 3.28 and master in different browsers.
> They show
> Uncaught ReferenceError: jQuery is not defined
>     at search.html?q=qgisinterface&check_keywords=yes&area=default:2239:7
>     at search.html?q=qgisinterface&check_keywords=yes&area=default:2244:5
> and an unrelated 404 for /_static/qgis.ico/ in the console.
> Cheers, Hannes
> Am 08.02.23 um 09:53 schrieb matteo via QGIS-Developer:
>> Hi Richard,
>> 3.28 is working fine for me here. I don't see any JQuery related
>> error in the debugging console.
>> Where are you seeing this error?
>> Cheers
>> Matteo
>> On 2/8/23 09:46, Richard Duivenvoorde wrote:
>>> Now 3.28 is also 'affected' ?
>>> In dev console I see:
>>> is some jquery cdn failing?
>>> Regards,
>>> On 2023-02-08 09:12, matteo via QGIS-Developer wrote:
>>>> Hi Denis,
>>>>> Is this related to this?
>>>>> https://github.com/qgis/pyqgis/commit/465d915555a265e4f1828f0da623d32f8ac7a1de
>>>>> <https://github.com/qgis/pyqgis/commit/465d915555a265e4f1828f0da623d32f8ac7a1de>
>>>>> Matteo, shall we try to revert?
>>>> not sure about that. I was searching in the docs till yesterday and it
>>>> was working. Has something changed in the last weeks?
>>>> Cheers
>>>> Matteo
>>>>> Cheers,
>>>>> Denis
>>>>> Le mer. 8 févr. 2023 à 08:58, matteo via QGIS-Developer
>>>>> <qgis-developer at lists.osgeo.org
>>>>> <mailto:qgis-developer at lists.osgeo.org>> a écrit :
>>>>>     Hi Richard,
>>>>>     I can confirm: searching in master will stay there forever
>>>>> without
>>>>>     finding anything.
>>>>>     Cheers
>>>>>     Matteo
>>>>>     On 2/8/23 08:52, Richard Duivenvoorde via QGIS-Developer wrote:
>>>>>      > Hi,
>>>>>      > Am I right to conclude something is wrong with PyQGIS api
>>>>> (DOCS
>>>>>     build)
>>>>>      > for master?
>>>>>      > https://qgis.org/pyqgis/master/search.html
>>>>>     <https://qgis.org/pyqgis/master/search.html>
>>>>>      > isn't working (missing jQuery?)
>>>>>      > while
>>>>>      > https://qgis.org/pyqgis/3.28/search.html
>>>>>     <https://qgis.org/pyqgis/3.28/search.html>
>>>>>      > is working (with me)?
>>>>>      > Others can confirm?
>>>>>      > Regards,
>>>>>      > Richard Duivenvoorde
>>>>>      > _______________________________________________
>>>>>      > QGIS-Developer mailing list
>>>>>      > QGIS-Developer at lists.osgeo.org
>>>>>     <mailto:QGIS-Developer at lists.osgeo.org>
>>>>>      > List info:
>>>>> https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>>>      > Unsubscribe:
>>>>>     List info:
>>>>>     Unsubscribe:
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
