[QGIS-Developer] Segmentation fault while compiling ui_DlgAddGeometryColumn.py
Denis Rouzaud denis.rouzaud at gmail.com
Thu Feb 16 11:18:59 PST 2023
Which commit are you building?
A recent master?
On Thu, 16 Feb 2023, 20:10 afernandez, <afernandez at odyhpc.com> wrote:
> Hi Denis,
> The system was clean, a completely new installation without any previous
> QGIS component. I could clean and try compiling again, but the compilation
> itself takes between 4 and 5 hours. I think that nothing would change as
> the starting point would be the same as previously. My thought is that I'd
> need to make some modification before cleaning and recompiling.
> Thanks,
> AFernandez
> Denis Rouzaud wrote:
> Hi,
> Can you make clean and build again?
> On Thu, 16 Feb 2023, 18:24 afernandez via QGIS-Developer, <
> qgis-developer at lists.osgeo.org> wrote:
>> Hello,
>> My compilation is failing towards the end with a segmentation fault
>> error, which I cannot figure out:
>> [ 85%] Linking CXX shared module ../output/python/qgis/_gui.so
>> [ 85%] Built target python_module_qgis__gui
>> [ 85%] Built target pygui
>> [ 85%] Generating ui_DlgAddGeometryColumn.py
>> Segmentation fault (core dumped)
>> make[2]: ***
>> [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:86:
>> python/plugins/db_manager/ui_DlgAddGeometryColumn.py] Error 139
>> make[2]: *** Deleting file
>> 'python/plugins/db_manager/ui_DlgAddGeometryColumn.py'
>> make[1]: *** [CMakeFiles/Makefile2:8465:
>> python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all]
>> Error 2
>> make: *** [Makefile:166: all] Error 2
>> Not really sure how to troubleshoot this. OS is Ubuntu22.04 and
>> architecture is aarch64.
>> Thanks.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230216/2678603a/attachment-0001.htm>
More information about the QGIS-Developer mailing list
