[QGIS-Developer] Segmentation fault while compiling ui_DlgAddGeometryColumn.py
afernandez afernandez at odyhpc.com
Thu Feb 16 11:45:03 PST 2023
Yes, I'm cloning from the master branch.
Denis Rouzaud wrote:
Which commit are you building?
A recent master?
On Thu, 16 Feb 2023, 20:10 afernandez, <afernandez at odyhpc.com
<mailto:afernandez at odyhpc.com> > wrote:
Hi Denis,
The system was clean, a completely new installation without any previous
QGIS component. I could clean and try compiling again, but the compilation
itself takes between 4 and 5 hours. I think that nothing would change as
the starting point would be the same as previously. My thought is that I'd
need to make some modification before cleaning and recompiling.
Thanks,
AFernandez
Can you make clean and build again?
On Thu, 16 Feb 2023, 18:24 afernandez via QGIS-Developer,
<qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org> >
wrote:
Hello,
My compilation is failing towards the end with a segmentation fault error,
which I cannot figure out:
[ 85%] Linking CXX shared module ../output/python/qgis/_gui.so
[ 85%] Built target python_module_qgis__gui
[ 85%] Built target pygui
[ 85%] Generating ui_DlgAddGeometryColumn.py
Segmentation fault (core dumped)
make[2]: ***
[python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:86:
python/plugins/db_manager/ui_DlgAddGeometryColumn.py] Error 139
make[2]: *** Deleting file
'python/plugins/db_manager/ui_DlgAddGeometryColumn.py'
make[1]: *** [CMakeFiles/Makefile2:8465:
python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all]
Error 2
make: *** [Makefile:166: all] Error 2
Not really sure how to troubleshoot this. OS is Ubuntu22.04 and
architecture is aarch64.
Thanks.
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
<https://lists.osgeo.org/mailman/listinfo/qgis-developer>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230216/63af5df2/attachment.htm>
More information about the QGIS-Developer mailing list
