[QGIS-Developer] createAlgorithmDialog in Processing script (within plugin)
matteo matteo.ghetta at gmail.com
Tue Feb 21 23:33:12 PST 2023
Hi Richard,
> Not very helpful for you, but what about creating an issue with the
> minimal code to crash?
done: https://github.com/qgis/QGIS/issues/51971
I've prepared a minimal algorithm that mimics the problem
> And about Thread/Crash problems: I have been succesful with the tips of
> Nyall in:
> https://lists.osgeo.org/pipermail/qgis-developer/2023-February/065525.html to create a QgsTask which either crashed or gave warnings...
> One thing I've seen recently is that some Processing algs with me give
> these "...is run from a different thread than the object  lives in
> ..."-warnings.
> And my feeling is that if some code is fetching references to the QGIS
> application instance, it shows this warning.
> Good luck solving your issue
Thanks! Some gurus around? :)
Cheers
Matteo
> Regards,
> Richard
> On 2/21/23 16:41, matteo via QGIS-Developer wrote:
>> Hi devs,
>> I'm raising this email again because I don't know if this a
>> bug/limitation/correct behavior.
>> I also think that the problem is from a thread point of view, at least
>> by the crash that I have.
>> Knowing that a processing algorithm, as suggested by Germàn, can be
>> created with:
>> processing.createAlgorithmDialog("my_provider:my_algorithm", params)
>> within a plugin, if the algorithm **id** is passed as first argument,
>> QGIS is crashing, while it seems working on a standalone script in the
>> QGIS code editor.
>> Is this a limitation?
>> Cheers and thanks for any suggestion!
>> Matteo
>> On 8/1/22 15:23, matteo wrote:
>>> Hi all,
>>> I've a set of custom processing scripts within a plugin (that is both
>>> "normal" and processing provider plugin).
>>> I'm trying to executing the dialog of these algorithm from one of the
>>> main plugin file. I found the processing.createAlgorithmDialog [0],
>>> but it is constantly crashing when I'm passing the instance of the
>>> algorithm:
>>> my_alg = MyCustomAlg()
>>> my_dialog = my_alg.createAlgorithmDialog(custom_dict)
>>> ## crash here
>>> Thinking it was a problem of the threads I also tried to overwrite
>>> the `flag` method in the algorithm by setting also
>>> QgsProcessingAlgorithm.FlagNoThreading but with the same results.
>>> I know I can run the processing algorithm with processing.run(....)
>>> but I need to open the dialog pre-filled with custom parameters and
>>> to get also some other outputs besides the standard ones (like the
>>> QgsFeatureSink path)
>>> Thanks for any suggestion
>>> Cheers
>>> Matteo
>>> [0]
>>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/general.py#L155
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
