[QGIS-Developer] createAlgorithmDialog in Processing script (within plugin)
matteo matteo.ghetta at gmail.com
Thu Feb 23 04:59:27 PST 2023
Just a quick update, the fix is now in master and backported:
https://github.com/qgis/QGIS/issues/51971
https://github.com/qgis/QGIS/pull/51985
Thanks to all the devs!
Cheers
Matteo
On 2/22/23 08:33, matteo wrote:
> Hi Richard,
>> Not very helpful for you, but what about creating an issue with the
>> minimal code to crash?
> done: https://github.com/qgis/QGIS/issues/51971
> I've prepared a minimal algorithm that mimics the problem
>> And about Thread/Crash problems: I have been succesful with the tips
>> of Nyall in:
>> https://lists.osgeo.org/pipermail/qgis-developer/2023-February/065525.html to create a QgsTask which either crashed or gave warnings...
>> One thing I've seen recently is that some Processing algs with me give
>> these "...is run from a different thread than the object  lives in
>> ..."-warnings.
>> And my feeling is that if some code is fetching references to the QGIS
>> application instance, it shows this warning.
>> Good luck solving your issue
> Thanks! Some gurus around? :)
> Cheers
> Matteo
>> Regards,
>> Richard
>> On 2/21/23 16:41, matteo via QGIS-Developer wrote:
>>> Hi devs,
>>> I'm raising this email again because I don't know if this a
>>> bug/limitation/correct behavior.
>>> I also think that the problem is from a thread point of view, at
>>> least by the crash that I have.
>>> Knowing that a processing algorithm, as suggested by Germàn, can be
>>> created with:
>>> processing.createAlgorithmDialog("my_provider:my_algorithm", params)
>>> within a plugin, if the algorithm **id** is passed as first argument,
>>> QGIS is crashing, while it seems working on a standalone script in
>>> the QGIS code editor.
>>> Is this a limitation?
>>> Cheers and thanks for any suggestion!
>>> Matteo
>>> On 8/1/22 15:23, matteo wrote:
>>>> Hi all,
>>>> I've a set of custom processing scripts within a plugin (that is
>>>> both "normal" and processing provider plugin).
>>>> I'm trying to executing the dialog of these algorithm from one of
>>>> the main plugin file. I found the processing.createAlgorithmDialog
>>>> [0], but it is constantly crashing when I'm passing the instance of
>>>> the algorithm:
>>>> my_alg = MyCustomAlg()
>>>> my_dialog = my_alg.createAlgorithmDialog(custom_dict)
>>>> ## crash here
>>>> Thinking it was a problem of the threads I also tried to overwrite
>>>> the `flag` method in the algorithm by setting also
>>>> QgsProcessingAlgorithm.FlagNoThreading but with the same results.
>>>> I know I can run the processing algorithm with processing.run(....)
>>>> but I need to open the dialog pre-filled with custom parameters and
>>>> to get also some other outputs besides the standard ones (like the
>>>> QgsFeatureSink path)
>>>> Thanks for any suggestion
>>>> Cheers
>>>> Matteo
>>>> [0]
>>>> https://github.com/qgis/QGIS/blob/master/python/plugins/processing/tools/general.py#L155
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
