[QGIS-Developer] parameterAsEnumStrings always return default value
Andrea Giudiceandrea andreaerdna at libero.it
Fri Feb 24 08:37:19 PST 2023
Hi Nicolas,
I don't know if it is the intended behaviour, anyway it seems to me
parameterAsEnumString and parameterAsEnumStrings return the correct
value when |usesStaticStrings is set to True, while parameterAsEnum and
parameterAsEnums when ||usesStaticStrings is set to False.
In addition, the parameter defaultValue should be set to a single value
and not to a list if ||allowMultiple is set to False.
Best regards.
Il 24/02/2023 14:11, Nicolas Godet via QGIS-Developer ha scritto:
> I noticed in a custom alg that `parameterAsEnumStrings` always return
> the default value set in QgsProcessingParameterEnum.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230224/2978a713/attachment.htm>
More information about the QGIS-Developer mailing list
