[QGIS-Developer] parameterAsEnumStrings always return default value
Andrea Giudiceandrea andreaerdna at libero.it
Fri Feb 24 08:50:29 PST 2023
Il 24/02/2023 17:37, Andrea Giudiceandrea ha scritto:
> |In addition, the parameter defaultValue should be set to a single
> value and not to a list if ||allowMultiple is set to False.|
|... and it should be populated with the index number
(|||||allowMultiple=False) |or a list of index numbers
(|||||allowMultiple=True) when |||||usesStaticStrings is set to False
and ||with the value |||(|||||allowMultiple=False) ||or a list of values
|||(|||||allowMultiple=True) when |||||usesStaticStrings is set to True.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230224/af31d593/attachment.htm>
More information about the QGIS-Developer mailing list
