[QGIS-Developer] No module named 'qgslayoutchecker' using "qgis/qgis:latest"
DelazJ delazj at gmail.com
Thu Jun 1 02:36:32 PDT 2023
Hi Matthias and list,
Thanks for the attempt but unfortunately this didn't solve the issue and
the doctest failure didn't stop popping. ;(
If ever someone wwants to give it another look, the docs repository
watchers would greatly appreciate.....
Greetings and thanks,
Harrissou
Le mar. 9 mai 2023 à 14:43, Matthias Kuhn <matthias at opengis.ch> a écrit :
> And it's open https://github.com/qgis/QGIS/pull/53053
> Thanks Paolo, thanks Harrissou
> On Tue, May 9, 2023 at 1:52 PM Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi Harrissou,
>> I have a branch ready but github errors with 500 at the moment. As soon
>> as they got their services under control again, the PR will be opened
>> Matthias
>> On Tue, May 9, 2023 at 12:07 PM DelazJ via QGIS-Developer <
>> qgis-developer at lists.osgeo.org> wrote:
>>> Hi devs,
>>> Can someone please give it a look. Having every single commit report a
>>> failure for no (valid) reason is quite noisy and annoying. (issue report at
>>> https://github.com/qgis/QGIS/issues/53051)
>>> Thanks,
>>> Harrissou
>>> Le mar. 2 mai 2023 à 10:02, DelazJ <delazj at gmail.com> a écrit :
>>>> Hi Paolo,
>>>> Yes, we do have the same problems with testing in QGIS-Documentation
>>>> repository, for everything related to master branch (
>>>> https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml?query=branch%3Amaster).
>>>> 3.28 is fine.
>>>> Regards,
>>>> Harrissou
>>>> Le mar. 2 mai 2023 à 08:44, Paolo Tormene via QGIS-Developer <
>>>> qgis-developer at lists.osgeo.org> a écrit :
>>>>> Dear QGIS people,
>>>>> I am running continuous integration tests for a plugin using the
>>>>> 'qgis/qgis:latest' docker and, since 4 days ago, I am getting the following
>>>>> error:
>>>>> from qgis.testing import start_app
>>>>> usr/lib/python3/dist-packages/qgis/utils.py:888: in _import
>>>>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>> usr/lib/python3/dist-packages/qgis/testing/__init__.py:56: in <module>
>>>>>     from qgslayoutchecker import QgsLayoutChecker
>>>>> E   ModuleNotFoundError: No module named 'qgslayoutchecker'
>>>>> Please note that the same tests run without issues using the
>>>>> 'qgis/qgis:release-3_22' docker instead.
>>>>> Has anyone experienced the same problem?
>>>>> Thank you and best regards,
>>>>> Paolo
>>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>>> <http://www.facebook.com/GEMwrld>
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230601/882b4fed/attachment.htm>
More information about the QGIS-Developer mailing list
