[QGIS-Developer] No module named 'qgslayoutchecker' using "qgis/qgis:latest"
DelazJ delazj at gmail.com
Fri Jun 2 01:57:16 PDT 2023
Hello,
Thanks Matthias for the new pull request. Green is back to the repo 👍!
Greetings,
Harrissou
Le jeu. 1 juin 2023 à 11:36, DelazJ <delazj at gmail.com> a écrit :
> Hi Matthias and list,
> Thanks for the attempt but unfortunately this didn't solve the issue and
> the doctest failure didn't stop popping. ;(
> If ever someone wwants to give it another look, the docs repository
> watchers would greatly appreciate.....
> Greetings and thanks,
> Harrissou
> Le mar. 9 mai 2023 à 14:43, Matthias Kuhn <matthias at opengis.ch> a écrit :
>> And it's open https://github.com/qgis/QGIS/pull/53053
>> Thanks Paolo, thanks Harrissou
>> On Tue, May 9, 2023 at 1:52 PM Matthias Kuhn <matthias at opengis.ch> wrote:
>>> Hi Harrissou,
>>> I have a branch ready but github errors with 500 at the moment. As soon
>>> as they got their services under control again, the PR will be opened
>>> Matthias
>>> On Tue, May 9, 2023 at 12:07 PM DelazJ via QGIS-Developer <
>>> qgis-developer at lists.osgeo.org> wrote:
>>>> Hi devs,
>>>> Can someone please give it a look. Having every single commit report a
>>>> failure for no (valid) reason is quite noisy and annoying. (issue report at
>>>> https://github.com/qgis/QGIS/issues/53051)
>>>> Thanks,
>>>> Harrissou
>>>> Le mar. 2 mai 2023 à 10:02, DelazJ <delazj at gmail.com> a écrit :
>>>>> Hi Paolo,
>>>>> Yes, we do have the same problems with testing in QGIS-Documentation
>>>>> repository, for everything related to master branch (
>>>>> https://github.com/qgis/QGIS-Documentation/actions/workflows/doctest.yml?query=branch%3Amaster).
>>>>> 3.28 is fine.
>>>>> Regards,
>>>>> Harrissou
>>>>> Le mar. 2 mai 2023 à 08:44, Paolo Tormene via QGIS-Developer <
>>>>> qgis-developer at lists.osgeo.org> a écrit :
>>>>>> Dear QGIS people,
>>>>>> I am running continuous integration tests for a plugin using the
>>>>>> 'qgis/qgis:latest' docker and, since 4 days ago, I am getting the following
>>>>>> error:
>>>>>> from qgis.testing import start_app
>>>>>> usr/lib/python3/dist-packages/qgis/utils.py:888: in _import
>>>>>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>>> usr/lib/python3/dist-packages/qgis/testing/__init__.py:56: in <module>
>>>>>>     from qgslayoutchecker import QgsLayoutChecker
>>>>>> E   ModuleNotFoundError: No module named 'qgslayoutchecker'
>>>>>> Please note that the same tests run without issues using the
>>>>>> 'qgis/qgis:release-3_22' docker instead.
>>>>>> Has anyone experienced the same problem?
>>>>>> Thank you and best regards,
>>>>>> Paolo
>>>>>> *PAOLO TORMENE* senior software developer +39 0382 5169882
>>>>>> *GLOBAL EARTHQUAKE MODEL * working together to assess risk
>>>>>> *GEM -* globalquakemodel.org <http://www.globalquakemodel.org> *T -*
>>>>>> @GEMwrld <http://twitter.com/GEMwrld> *F -* GEMwrld
>>>>>> <http://www.facebook.com/GEMwrld>
>>>>>> _______________________________________________
>>>>>> QGIS-Developer mailing list
>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230602/f6564839/attachment.htm>
More information about the QGIS-Developer mailing list
