[QGIS-Developer] Properly terminating a QgsTask?
    Benjamin Jakimow
    benjamin.jakimow at geo.hu-berlin.de
    Mon Jun  5 04:27:16 PDT 2023
Hi Johannes,
just stop the execution in QgsTask::run(), for example using a break
that stops a loop, and return False instead of True.
 From https://api.qgis.org/api/3.30/classQgsTask.html
> Performs the task's operation.
> This method will be called when the task commences (ie via calling
> start() ), and subclasses should implement the operation they wish to
> perform in the background within this method.
> A task must return a boolean value to indicate whether the task was
> completed successfully or terminated before completion.
> virtual bool QgsTask::run 	(
> 	protectedpure virtual
Greetings, Benjamin
Am 02.06.2023 um 14:19 schrieb Johannes Kröger (WhereGroup) via
QGIS-Developer:
> Hi,
> https://qgis.org/pyqgis/3.30/core/QgsTask.html says
> > Long running tasks should periodically check the isCanceled() flag
> to detect if the task has been canceled via some external event. If
> this flag is True then the task should clean up and terminate at the
> earliest possible convenience.
> How are we supposed to "terminate" a task properly?
> If we check for task.isCanceled() (or call task.cancel() ourselves for
> testing) and simply return:
> - QGIS will still show a notification that the "Task completed"
> (instead of "Task failed")
> (https://github.com/qgis/QGIS/blob/d3d0431685883b837caa571ad7282828cfbde65e/src/app/qgisapp.cpp#L15707)
> - The taskTerminated signal is not emitted. But the taskCompleted
> signal is emitted.
> - The task's status is QgsTask.Complete
> There is no obvious way to "terminate" the task from the Python side.
> We cannot set the task's status attribute to QgsTask.Terminated
> (https://qgis.org/pyqgis/3.30/core/QgsTask.html#qgis.core.QgsTask.Terminated).
> If an exception happens in the task then it seems to terminate
> "properly", i.e. its status will be QgsTask.Terminated, the
> taskTerminated signal is emitted and a notification "Task failed" is
> shown. This is the only way I found today to get into this state. I
> have not found this documented and only by accident...
> Example for a QgsTask.fromFuncction(..., flags=QgsTask.CanCancel),
> uncomment one of the final lines:
> def foo(task):
>         time.sleep(6)  # must be >= minTaskLengthForSystemNotification
> (5 by default)
>         #task.cancel(); return  # -> Task complete
>         #raise Exception("fail plz")  # -> Task failed
> It feels like a bug to me (either task.cancel should directly set its
> status to QgsTask.Terminated or we should have a task.setStatus()
> method) but everything in and around QgsTask is fairly opaque and hard
> to grasp so maybe I am just missing something obvious.
> Cheers, Hannes
> PS: I did not test the example function in a clean environment, in my
> test cases I have code like this as methods of a class.
Dr. Benjamin Jakimow
Earth Observation Lab | Geography Department | Humboldt-Universität zu Berlin
e-mail:benjamin.jakimow at geo.hu-berlin.de
web:https://hu-berlin.de/eo-lab
phone:  +49 (0) 30 2093 6846
mobile: +49 (0) 157 5656 8477
fax:    +49 (0) 30 2093 6848
mail:   Unter den Linden 6 | 10099 Berlin | Germany
room: 2'211
linkedin:https://www.linkedin.com/in/benjamin-jakimow
matrix: @jakimowb:hu-berlin.de
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230605/529bf2f0/attachment.htm>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230605/529bf2f0/attachment.bin>
