[QGIS-Developer] py3_env not recognized in versions later than 3.16
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Jun 13 07:35:59 PDT 2023
Il 13/06/2023 15:26, Luis Eduardo via QGIS-Developer ha scritto:
> Hello
> I need to install Pytorch in QGIS 3.22, 3.28, using pip but I can't
> configure the environment, py3_env is not recognized.
Hi Luis Eduardo,
AFAIK py3_env is no longer available in the OSGeo4W Shell and it is no
longer needed because OSGeo4W uses Python 3 by default since a couple of
years (since 3.16 msi/v2).
> And through the OSGEO installer the library is not available.
Have you tried using python -m pip install ....?
Best regards.
Andrea
