[QGIS-Developer] py3_env not recognized in versions later than 3.16
Jürgen E. Fischer jef at norbit.de
Tue Jun 13 09:18:47 PDT 2023
Hi Luis,
On Tue, 13. Jun 2023 at 13:26:12 +0000, Luis Eduardo via QGIS-Developer wrote:
> HelloI need to install Pytorch in QGIS 3.22, 3.28, using pip but I can't
> configure the environment, py3_env is not recognized.And through the OSGEO
> installer the library is not available.
Huh?  py3_env.bat was used in OSGeo4W to switch from the default python2
install to python3.  As OSGeo4W v2 only has python3, py3_env is not needed
anymore.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230613/8aaa85a5/attachment.sig>
More information about the QGIS-Developer mailing list
