[QGIS-Developer] QGIS builds source for qtwebkit?
Alexandre Neto senhor.neto at gmail.com
Mon Jun 19 00:51:41 PDT 2023
Hi Jürgen!
Thanks you very much.
Alex
A domingo, 18/06/2023, 21:09, Jürgen E. Fischer via QGIS-Developer <
qgis-developer at lists.osgeo.org> escreveu:
> Hi Alex,
> On Fri, 16. Jun 2023 at 13:39:26 +0000, Alexandre Neto via QGIS-Developer
> wrote:
> > Are we (actually Jürgen) building qtwebkit from source? what is the
> source that is being used. At conda-forge we were using the link below,
> which was removed from qt.io <http://qt.io> site.
> http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz
> The recipe is at
> https://github.com/jef-n/OSGeo4W/blob/master/src/qtwebkit/osgeo4w/package.sh
> so the package was built with:
> https://github.com/qtwebkit/qtwebkit/releases/download/qtwebkit-5.212.0-alpha4/qtwebkit-5.212.0-alpha4.tar.xz
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230619/38a4b28f/attachment.htm>
More information about the QGIS-Developer mailing list
