[QGIS-Developer] QGIS builds source for qtwebkit?
Alexandre Neto
senhor.neto at gmail.com
Mon Jun 19 03:39:21 PDT 2023
One more question,
Are there any plans to use the new sources? There's only a pre-release by now, but at least it's active.
Thanks,
On Mon Jun 19, 2023, 07:51 AM GMT, Alexandre Neto <mailto:senhor.neto at gmail.com> wrote:
> Hi Jürgen!
> Thanks you very much.
> Alex
> A domingo, 18/06/2023, 21:09, Jürgen E. Fischer via QGIS-Developer <qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>> escreveu:
>> Hi Alex,
>> On Fri, 16. Jun 2023 at 13:39:26 +0000, Alexandre Neto via QGIS-Developer wrote:
>> > Are we (actually Jürgen) building qtwebkit from source? what is the source that is being used. At conda-forge we were using the link below, which was removed from qt.io <http://qt.io> <http://qt.io <http://qt.io>> site.
>> > http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz <http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz> <http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz <http://download.qt.io/snapshots/ci/qtwebkit/5.212/1600955993/src/submodules/qtwebkit-opensource-src-5.212.tar.xz>>
>> The recipe is at
>> https://github.com/jef-n/OSGeo4W/blob/master/src/qtwebkit/osgeo4w/package.sh <https://github.com/jef-n/OSGeo4W/blob/master/src/qtwebkit/osgeo4w/package.sh>
>> so the package was built with:
>> https://github.com/qtwebkit/qtwebkit/releases/download/qtwebkit-5.212.0-alpha4/qtwebkit-5.212.0-alpha4.tar.xz <https://github.com/qtwebkit/qtwebkit/releases/download/qtwebkit-5.212.0-alpha4/qtwebkit-5.212.0-alpha4.tar.xz>
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
>> Software Engineer D-26506 Norden https://www.norbit.de <https://www.norbit.de>
>> QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230619/6f389fda/attachment.htm>
