[QGIS-Developer] Adding a plugin collaborator
Richard Duivenvoorde rdmailings at duif.net
Thu Jun 22 00:13:30 PDT 2023
Or maybe... the 'author' string of the metadata.txt is used as is.
If you leave it, it will probably use the name from your
credentials/ldap.
But if you add more names there, it will be shown in the plugin
dialog(s)
Regards,
Richard
On 2023-06-22 09:08, Richard Duivenvoorde via QGIS-Developer wrote:
> On 2023-06-22 06:34, Nyall Dawson via QGIS-Developer wrote:
>> Hi list,
>> This is possibly a stupid question -- but how can I add additional
>> users as collaborators to a plugin via https://plugins.qgis.org/?
>> I can see other plugins which have done this, but can't see any
>> settings exposed in my plugins which permit me to add collaborations
>> myself.
> As admin it it possible to change 'owners'. That is if the ownership
> changes, I (or other admins) can do that in the plugins.qgis.org site.
> For metadata fields:
> https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html#metadata-txt
> Not sure what you mean with collaborator?
> Can you give an example of such 'collaborator'?
> Or if you let me know, I dan make a person 'owner' too...
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
