[QGIS-Developer] QGIS Full Stack Web Developer Report
Lova Andriarimalala lova at kartoza.com
Thu Nov 23 23:35:42 PST 2023
Dear Julien,
Many thanks for your feedback.
In the new PR, the license file is only required for new plugins. For existing plugin updates, it generates just a warning (but doesn't fail) when the license file is missing.
However, I'm not sure if we should also just generate a warning for new plugin uploads for now. If so, I will also fix the new plugin upload.
Kind regards.
[Image]
Lova Andriarimalala
QGIS Full Stack Developer
Visit http://kartoza.com<http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Office: +261(0)34 09 524 73<tel:+261340952473>
From: QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on behalf of Julien Moura via QGIS-Developer <qgis-developer at lists.osgeo.org>
Date: Friday, 24 November 2023 at 10:30 AM
To: qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] QGIS Full Stack Web Developer Report
Hello Lova,
I cross post my comment to this issue<https://github.com/qgis/QGIS-Django/issues/38#issuecomment-1824010198> related to the PR mentioned below as "Make LICENSE file as required in plugin package<https://github.com/qgis/QGIS-Django/pull/309>", because I did not have any answer there but saw that some changes still have been applied without any comment.
While trying to publish or update a plugin, we faced the new error message related to the deployment of this PR<https://github.com/qgis/QGIS-Django/pull/309>:
> Fault string: <Fault 1: 'File upload must be a valid QGIS Python plugin compressed archive. Cannot find LICENSE in plugin package.'>
See downstream issue on qgis-plugin-ci project (disclaimer: I'm one of the mainteners but speaking on my own here): https://github.com/opengisch/qgis-plugin-ci/issues/255
I think this kind of change, which breaks the plugins'publication flow, should be discussed before to be implemented (an issue from 1 person seems to be too light to decide without any discussion), announced to the community, a warning campaign should be run and a transitional phase should be implemented (warning for 6 months, then error). This has a direct impact on hundreds (thousands?) of plugin developers on a community project with several million end users.
I understand that this process may seem too cumbersome, and that since the QGIS Django project hasn't been so dynamic for a few years, it's nice to see it get a new lease of life, even if it means merging and deploying on an ongoing basis.
As for the underlying principle, I'm generally in favor of strengthening the control mechanisms (automatic or otherwise) for extensions on the official repository, but I think it's really important to do this gradually, or at least to avoid unilateral change "descended from the skies of the developers".
Concerning the idea of integrating the license in the plugin package, I'm not really convinced of the interest since most plugins are contaminated by the GPL2+ of QGIS <-- Qt and the license is never displayed to the end user. But why not. After all, it's always a good practice to include licence and spread the word about (re)usage rules.
Reverting sounds maybe too rought so I suggest modyfing the behavior to lower the level and make it a simple warning and in the meanwhile starting a communication and preventive work upstream:
  1.  update documentation: https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html
  2.  communicate on the QGIS Dev list **before** the implementation to discuss the rationale
  3.  integrate a warning mechanism
  4.  manage the QGIS versions concerned (only applicable to new QGIS released versions after this being merged)
A last question: did you have some pre-production environment where to deploy new changes in order to evaluate them before publishing widely? Or some versioning logic, milestone workflow where PRs are grouped before being deployed?
Regards,
Julien
On 17/11/2023 13:59, Lova Andriarimalala via QGIS-Developer wrote:
Hello everyone,
Please find below the report summarizing the progress on the feed and plugins website development for this week.
PRs open:
1.       Add support for renaming plugin name<https://github.com/qgis/QGIS-Django/pull/302>
2.       Add command to fix none in search results<https://github.com/qgis/QGIS-Django/pull/304>
3.       Show more records, records items per page<https://github.com/qgis/QGIS-Django/pull/306>
4.       Specify tag page title and other plugin page title<https://github.com/qgis/QGIS-Django/pull/308>
5.       Make LICENSE file as required in plugin package<https://github.com/qgis/QGIS-Django/pull/309>
PR merged:
6.       Update dockerfile and requirements for production<https://github.com/qgis/qgis-feed/pull/44>
7.       Update requirements according to production<https://github.com/qgis/qgis-feed/pull/47>
8.       Add geoip2 in production, setting up log<https://github.com/qgis/qgis-feed/pull/48>
9.       Use contry code when testing daily_visit.country<https://github.com/qgis/qgis-feed/pull/51>
Still working on:
1.       Fresh plugin includes obsolete stuff <https://github.com/qgis/QGIS-Django/issues/46>
Changes to the QGIS Feed website are now deployed and available at https://feed.qgis.org.
Have a great weekend,
Lova
[Image]
Lova Andriarimalala
* GIS Training
From: Lova Andriarimalala <lova at kartoza.com><mailto:lova at kartoza.com>
Date: Friday, 10 November 2023 at 5:32 PM
To: qgis-developer at lists.osgeo.org<mailto:qgis-developer at lists.osgeo.org> <qgis-developer at lists.osgeo.org><mailto:qgis-developer at lists.osgeo.org>
Subject: Re: QGIS Full Stack Web Developer Report
Hello everyone,
PRs open:
10.    Add support for renaming plugin name<https://github.com/qgis/QGIS-Django/pull/302>
11.    Update dockerfile and requirements for production<https://github.com/qgis/qgis-feed/pull/44>
PR merged:
1.       Add web page UI on the root URL<https://github.com/qgis/qgis-feed/pull/43>
Still working on:
2.       Deployment of the feed updates
Lova
[Image]
Lova Andriarimalala
* GIS Training
Date: Friday, 3 November 2023 at 5:05 PM
Hello everyone,
Please find below the report summarizing the progress on the feed site development for this week.
PRs open:
PR merged:
  1.  Using rich editor for content, check data validity<https://github.com/qgis/qgis-feed/pull/42>
Still working on:
  1.  Some checks and fixes on the entirety<https://github.com/qgis/qgis-feed/issues/18>
Lova
[Image]
Lova Andriarimalala
* GIS Training
Date: Friday, 27 October 2023 at 4:53 PM
Hello everyone,
I'm grateful for your warm welcome, and I'm truly thrilled to join this wonderful community.
Here is the report summarizing the progress on the feed site development for this week.
PRs open:
     *   Form submission management<https://github.com/qgis/qgis-feed/pull/39>
PR merged:
     *   Feeds list page with filter and sorting<https://github.com/qgis/qgis-feed/pull/30>
     *   Feed item form with preview<https://github.com/qgis/qgis-feed/pull/32>
     *   Feed form review step<https://github.com/qgis/qgis-feed/pull/33>
     *   Implement webpack and use it for Bulma CSS<https://github.com/qgis/qgis-feed/pull/34>
Still working on:
     *   Improve feed item form: Check data validity<https://github.com/qgis/qgis-feed/issues/25>
Lova
[cid:9A13FDC2-2DFE-48D9-9736-E7E67663BF60]
Lova Andriarimalala
* GIS Training
Date: Friday, 20 October 2023 at 2:54 PM
Subject: QGIS Full Stack Web Developer Report
Hello everyone,
Currently, I am working on the website that administers the feeds displayed in the news area of QGIS. The website's repository is available on GitHub: https://github.com/qgis/qgis-feed
Please find below the report for the past two weeks.
PRs open:
PR merged:
     *   Create a login page, add test cases, configure GH actions<https://github.com/qgis/qgis-feed/pull/28>
Still working on:
     *   Use web pack for bulma CSS<https://github.com/qgis/qgis-feed/issues/29>
Please do not hesitate to provide any feedback regarding the report structure or layout. Your suggestions are highly appreciated, as they will enable us to improve the report's quality and readability. Thank you for taking the time to review the report.
Lova
[cid:E4BD0DDE-7267-4E95-BE4E-92E12A6851D3]
Lova Andriarimalala
* GIS Training
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/cb297735/attachment-0001.htm>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/cb297735/attachment-0002.jpg>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/cb297735/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
