[QGIS-Developer] QGIS Full Stack Web Developer Report
Julien Moura julien.moura at oslandia.com
Thu Nov 23 23:47:56 PST 2023
Thanks for your quick reply here Lova,
I've no special legibility that my opinion would be greater than yours,
so I can't tell if it has to be reverted or not. That's why I ask for
discussion before deploying some breaking change, without any warning or
information. After having looked to others PR, I would like to see more
description about what a PR does exactly, especially when it breaks
something.
In this case, even after the last PR, this is a breaking and
undocumented change. For now, a plugin developer has no way to see that
a LICENSE file is now required in its plugin's zip. An error message in
a log is not a suitable information, even it's well formulated and
clear, especially in the era of automated CI/CD deployments.
Regards,
Julien
On 24/11/2023 08:35, Lova Andriarimalala wrote:
> Dear Julien,
> Many thanks for your feedback.
> In the newPR, the license file is only required for new plugins. For
> existing plugin updates, it generates just a warning (but doesn't
> fail) when the license file is missing.
> However, I'm not sure if we should also just generate a warning for
> new plugin uploads for now. If so, I will also fix the new plugin upload.
> Kind regards.
> Image
> *Lova Andriarimalala***
> *QGIS Full Stack Developer***
> Visit http://kartoza.com <http://kartoza.com/> to find out about open
> source:
> * Desktop GIS programming services
> * Geospatial web development
> * GIS Training
> * Consulting Services
> Office: +261(0)34 09 524 73 <tel:+261340952473>
> *From: *QGIS-Developer <qgis-developer-bounces at lists.osgeo.org> on
> behalf of Julien Moura via QGIS-Developer <qgis-developer at lists.osgeo.org>
> *Date: *Friday, 24 November 2023 at 10:30 AM
> *To: *qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
> *Subject: *Re: [QGIS-Developer] QGIS Full Stack Web Developer Report
> Hello Lova,
> I cross post my comment to this issue
> <https://github.com/qgis/QGIS-Django/issues/38#issuecomment-1824010198>
> related to the PR mentioned below as "Make LICENSE file as required in
> plugin package <https://github.com/qgis/QGIS-Django/pull/309>",
> because I did not have any answer there but saw that some changes
> still have been applied without any comment.
> While trying to publish or update a plugin, we faced the new error
> message related to the deployment of this PR
> <https://github.com/qgis/QGIS-Django/pull/309>:
> > Fault string: <Fault 1: 'File upload must be a valid QGIS Python
> plugin compressed archive. Cannot find LICENSE in plugin package.'>
> See downstream issue on qgis-plugin-ci project (disclaimer: I'm one of
> the mainteners but speaking on my own here):
> https://github.com/opengisch/qgis-plugin-ci/issues/255
> I think this kind of change, which breaks the plugins'publication
> flow, should be discussed before to be implemented (an issue from 1
> person seems to be too light to decide without any discussion),
> announced to the community, a warning campaign should be run and a
> transitional phase should be implemented (warning for 6 months, then
> error). This has a direct impact on hundreds (thousands?) of plugin
> developers on a community project with several million end users.
> I understand that this process may seem too cumbersome, and that since
> the QGIS Django project hasn't been so dynamic for a few years, it's
> nice to see it get a new lease of life, even if it means merging and
> deploying on an ongoing basis.
> As for the underlying principle, I'm generally in favor of
> strengthening the control mechanisms (automatic or otherwise) for
> extensions on the official repository, but I think it's really
> important to do this gradually, or at least to avoid unilateral change
> "descended from the skies of the developers".
> Concerning the idea of integrating the license in the plugin package,
> I'm not really convinced of the interest since most plugins are
> contaminated by the GPL2+ of QGIS <-- Qt and the license is never
> displayed to the end user. But why not. After all, it's always a good
> practice to include licence and spread the word about (re)usage rules.
> Reverting sounds maybe too rought so I suggest modyfing the behavior
> to lower the level and make it a simple warning and in the meanwhile
> starting a communication and preventive work upstream:
>  1. update documentation:
>     https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html
>  2. communicate on the QGIS Dev list **before** the implementation to
>     discuss the rationale
>  3. integrate a warning mechanism
>  4. manage the QGIS versions concerned (only applicable to new QGIS
>     released versions after this being merged)
> A last question: did you have some pre-production environment where to
> deploy new changes in order to evaluate them before publishing widely?
> Or some versioning logic, milestone workflow where PRs are grouped
> before being deployed?
> Regards,
> Julien
> On 17/11/2023 13:59, Lova Andriarimalala via QGIS-Developer wrote:
>     Hello everyone,
>     Please find below the report summarizing the progress on the feed
>     and plugins websitedevelopment for this week.
>     *PRs open:*
>     1.Add support for renaming plugin name
>     <https://github.com/qgis/QGIS-Django/pull/302>
>     2.Add command to fix none in search results
>     <https://github.com/qgis/QGIS-Django/pull/304>
>     3.Show more records, records items per page
>     <https://github.com/qgis/QGIS-Django/pull/306>
>     4.Specify tag page title and other plugin page title
>     <https://github.com/qgis/QGIS-Django/pull/308>
>     5.Make LICENSE file as required in plugin package
>     *PR merged:*
>     6.Update dockerfile and requirements for production
>     <https://github.com/qgis/qgis-feed/pull/44>
>     7.Update requirements according to production
>     <https://github.com/qgis/qgis-feed/pull/47>
>     8.Add geoip2 in production, setting up log
>     <https://github.com/qgis/qgis-feed/pull/48>
>     9.Use contry code when testing daily_visit.country
>     <https://github.com/qgis/qgis-feed/pull/51>
>     *Still working on:*
>     1.Fresh plugin includes obsolete stuff
>     <https://github.com/qgis/QGIS-Django/issues/46>
>     Changes to the QGIS Feed website are now deployed and available at
>     https://feed.qgis.org.
>     Have a great weekend,
>     Lova
>     Image
>     open source:
>     * GIS Training
>     *From: *Lova Andriarimalala <lova at kartoza.com>
>     <mailto:lova at kartoza.com>
>     *Date: *Friday, 10 November 2023 at 5:32 PM
>     <mailto:qgis-developer at lists.osgeo.org>
>     *Subject: *Re: QGIS Full Stack Web Developer Report
>     Hello everyone,
>     *PRs open:*
>     10.Add support for renaming plugin name
>     11.Update dockerfile and requirements for production
>     *PR merged:*
>     1.Add web page UI on the root URL
>     <https://github.com/qgis/qgis-feed/pull/43>
>     *Still working on:*
>     2.Deployment of the feed updates
>     Lova
>     Image
>     open source:
>     * GIS Training
>     *Date: *Friday, 3 November 2023 at 5:05 PM
>     Hello everyone,
>     site development for this week.
>         *PRs open:*
>          1. Add web page UI on the root URL
>         *PR merged:*
>          1. Using rich editor for content, check data validity
>             <https://github.com/qgis/qgis-feed/pull/42>
>         *Still working on:*
>          1. Some checks and fixes on the entirety
>             <https://github.com/qgis/qgis-feed/issues/18>
>     Lova
>     Image
>     *QGIS Full Stack Web Developer*
>     open source:
>     * GIS Training
>     Office: _+261(0)34 09 524 73_
>     *Date: *Friday, 27 October 2023 at 4:53 PM
>     Hello everyone,
>     I'm grateful for your warm welcome, and I'm truly thrilled to join
>     this wonderful community.
>     Here is the report summarizing the progress on the feed site
>     *PRs open:*
>          1. Form submission management
>             <https://github.com/qgis/qgis-feed/pull/39>
>     *PR merged:*
>          1. Feeds list page with filter and sorting
>             <https://github.com/qgis/qgis-feed/pull/30>
>          2. Feed item form with preview
>             <https://github.com/qgis/qgis-feed/pull/32>
>          3. Feed form review step
>             <https://github.com/qgis/qgis-feed/pull/33>
>          4. Implement webpack and use it for Bulma CSS
>             <https://github.com/qgis/qgis-feed/pull/34>
>     *Still working on:*
>          1. Improve feed item form: Check data validity
>             <https://github.com/qgis/qgis-feed/issues/25>
>     Lova
>     open source:
>     * GIS Training
>     *Date: *Friday, 20 October 2023 at 2:54 PM
>     *Subject: *QGIS Full Stack Web Developer Report
>     Hello everyone,
>     Currently, I am working on the website that administers the feeds
>     displayed in the news area of QGIS. The website's repository is
>     available on GitHub: https://github.com/qgis/qgis-feed
>     <https://github.com/qgis/qgis-feed>
>     Please find below the report for the past two weeks.
>     *PRs open:*
>     *PR merged:*
>          1. Create a login page, add test cases, configure GH actions
>             <https://github.com/qgis/qgis-feed/pull/28>
>     *Still working on:*
>          1. Use web pack for bulma CSS
>             <https://github.com/qgis/qgis-feed/issues/29>
>     Please do not hesitate to provide any feedback regarding the
>     report structure or layout. Your suggestions are highly
>     appreciated, as they will enable us to improve the report's
>     quality and readability. Thank you for taking the time to review
>     the report.
>     Lova
>     open source:
>     * GIS Training
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org
>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/c78f80a0/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/c78f80a0/attachment-0001.jpg>
Type: text/vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/c78f80a0/attachment-0001.vcf>
More information about the QGIS-Developer mailing list
