[QGIS-Developer] QGIS Full Stack Web Developer Report
Julien Moura julien.moura at oslandia.com
Fri Nov 24 02:38:34 PST 2023
Dear Tim,
Thanks for taking in account my thoughts and make the discussion possible.
Regarding the second about change management, I totally agree and feel
really thankful that you make those changes. I can imagine the work it
represents for your teams maintaining a project like this one. So thank
you again.
Regarding your proposal about the license requirements, why not starting
apply the change management to this? It's a breaking change, even for
new plugins, right? So, it should be lowered to a non blocking warning,
documented in PyQGIS cookbook and then deployed as a blocking error in a
known time windows. This way, in the meanwhile, the plugins ecosystem
can adapt to new rules (new versions for tools like minimal plugin,
qgis-plugin-ci, plugin builder...) and make this change more acceptable
and frictionless.
Moreover, the rationale behind the required license file into the plugin
archive is still not solved.
If you want, I can make a PR to change the warning but I'm pretty sure
that's not the question here.
> https://github.com/orgs/qgis/projects/6
Just to let you know this hyperlink leads to a 404 (probably a Github
rights access setting somewhere).
Regards
On 24/11/2023 10:50, Tim Sutton wrote:
> Dear Julien
> Thank you so much for your engagement and suggestions. Fully agreed
> that breaking changes should be well communicated first. So splitting
> the discussion in two:
> 1) License requirements: for now I have chatted with Lova and we propose:
> a) Change the logic such that a license is required for newly
> registered plugins
> b) When updates are made to existing plugins that do not include a
> license, the uploader will be shown a warning indicating that in
> future the license will  be mandatory
> This is already implemented in
> https://github.com/qgis/QGIS-Django/pull/311 and I propose we deploy
> this today / ASAP to address the previously raised issues.
> 2) Change management:
> Yes I think we can introduce more rigour in the process.
> * breaking changes: discuss with the community first, implement,
> deploy in a known time window
> * non-breaking changes: for simple bug fixes, just fix, test and
> deploy as needed
> * non-breaking changes: for features etc. these will be managed on the
> project board here, anyone who wants to be engaged in the process can
> see the planned upcomming work and interact with Lova via the ticket
> queue. https://github.com/orgs/qgis/projects/6
> * requests to improvements: please file tickets here
> https://github.com/qgis/QGIS-Django/issues
> Regarding a staging site, currently we do not run a staging
> environment, developers have local test environments and I am on the
> fence as to whether there is a lot of value in us maintaining a long
> running staging site.
> Regards
> Tim
> On Fri, Nov 24, 2023 at 8:08 AM Lova Andriarimalala via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
>     Dear Julien,
>     That’s well noted. Thank you.
>     I will add a detailed description in each PR in the future.
>     Regarding the issue of LICENSE file requirements, I totally agree
>     with you. I will also ask Tim if he has suggestions about it.
>     Best regards,
>     Lova
>     Image
>     *Lova Andriarimalala***
>     *QGIS Full Stack Developer***
>     Visit http://kartoza.com <http://kartoza.com/> to find out about
>     open source:
>     * Desktop GIS programming services
>     * Geospatial web development
>     * GIS Training
>     * Consulting Services
>     Office: +261(0)34 09 524 73 <tel:+261340952473>
>     *From: *Julien Moura <julien.moura at oslandia.com>
>     *Date: *Friday, 24 November 2023 at 10:47 AM
>     *To: *Lova Andriarimalala <lova at kartoza.com>,
>     qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
>     *Subject: *Re: [QGIS-Developer] QGIS Full Stack Web Developer Report
>     Thanks for your quick reply here Lova,
>     I've no special legibility that my opinion would be greater than
>     yours, so I can't tell if it has to be reverted or not. That's why
>     I ask for discussion before deploying some breaking change,
>     without any warning or information. After having looked to others
>     PR, I would like to see more description about what a PR does
>     exactly, especially when it breaks something.
>     In this case, even after the last PR, this is a breaking and
>     undocumented change. For now, a plugin developer has no way to see
>     that a LICENSE file is now required in its plugin's zip. An error
>     message in a log is not a suitable information, even it's well
>     formulated and clear, especially in the era of automated CI/CD
>     deployments.
>     Regards,
>     Julien
>     On 24/11/2023 08:35, Lova Andriarimalala wrote:
>         Dear Julien,
>         Many thanks for your feedback.
>         In the newPR, the license file is only required for new
>         plugins. For existing plugin updates, it generates just a
>         warning (but doesn't fail) when the license file is missing.
>         However, I'm not sure if we should also just generate a
>         warning for new plugin uploads for now. If so, I will also fix
>         the new plugin upload.
>         Kind regards.
>         Image
>         about open source:
>         * GIS Training
>         *From: *QGIS-Developer
>         <qgis-developer-bounces at lists.osgeo.org>
>         <mailto:qgis-developer-bounces at lists.osgeo.org> on behalf of
>         Julien Moura via QGIS-Developer
>         <mailto:qgis-developer at lists.osgeo.org>
>         *Date: *Friday, 24 November 2023 at 10:30 AM
>         *To: *qgis-developer at lists.osgeo.org
>         Report
>         Hello Lova,
>         I cross post my comment to this issue
>         <https://github.com/qgis/QGIS-Django/issues/38#issuecomment-1824010198>
>         related to the PR mentioned below as "Make LICENSE file as
>         required in plugin package
>         <https://github.com/qgis/QGIS-Django/pull/309>", because I did
>         not have any answer there but saw that some changes still have
>         been applied without any comment.
>         While trying to publish or update a plugin, we faced the new
>         error message related to the deployment of this PR
>         <https://github.com/qgis/QGIS-Django/pull/309>:
>         > Fault string: <Fault 1: 'File upload must be a valid QGIS
>         Python plugin compressed archive. Cannot find LICENSE in
>         plugin package.'>
>         See downstream issue on qgis-plugin-ci project (disclaimer:
>         I'm one of the mainteners but speaking on my own here):
>         https://github.com/opengisch/qgis-plugin-ci/issues/255
>         I think this kind of change, which breaks the
>         plugins'publication flow, should be discussed before to be
>         implemented (an issue from 1 person seems to be too light to
>         decide without any discussion), announced to the community, a
>         warning campaign should be run and a transitional phase should
>         be implemented (warning for 6 months, then error). This has a
>         direct impact on hundreds (thousands?) of plugin developers on
>         a community project with several million end users.
>         I understand that this process may seem too cumbersome, and
>         that since the QGIS Django project hasn't been so dynamic for
>         a few years, it's nice to see it get a new lease of life, even
>         if it means merging and deploying on an ongoing basis.
>         As for the underlying principle, I'm generally in favor of
>         strengthening the control mechanisms (automatic or otherwise)
>         for extensions on the official repository, but I think it's
>         really important to do this gradually, or at least to avoid
>         unilateral change "descended from the skies of the developers".
>         Concerning the idea of integrating the license in the plugin
>         package, I'm not really convinced of the interest since most
>         plugins are contaminated by the GPL2+ of QGIS <-- Qt and the
>         license is never displayed to the end user. But why not. After
>         all, it's always a good practice to include licence and spread
>         the word about (re)usage rules.
>         Reverting sounds maybe too rought so I suggest modyfing the
>         behavior to lower the level and make it a simple warning and
>         in the meanwhile starting a communication and preventive work
>         upstream:
>          1. update documentation:
>             https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html
>          2. communicate on the QGIS Dev list **before** the
>             implementation to discuss the rationale
>          3. integrate a warning mechanism
>          4. manage the QGIS versions concerned (only applicable to new
>             QGIS released versions after this being merged)
>         A last question: did you have some pre-production environment
>         where to deploy new changes in order to evaluate them before
>         publishing widely? Or some versioning logic, milestone
>         workflow where PRs are grouped before being deployed?
>         Regards,
>         Julien
>         On 17/11/2023 13:59, Lova Andriarimalala via QGIS-Developer wrote:
>             Hello everyone,
>             Please find below the report summarizing the progress on
>             the feed and plugins websitedevelopment for this week.
>             *PRs open:*
>             1.Add support for renaming plugin name
>             <https://github.com/qgis/QGIS-Django/pull/302>
>             2.Add command to fix none in search results
>             <https://github.com/qgis/QGIS-Django/pull/304>
>             3.Show more records, records items per page
>             <https://github.com/qgis/QGIS-Django/pull/306>
>             4.Specify tag page title and other plugin page title
>             <https://github.com/qgis/QGIS-Django/pull/308>
>             5.Make LICENSE file as required in plugin package
>             *PR merged:*
>             6.Update dockerfile and requirements for production
>             <https://github.com/qgis/qgis-feed/pull/44>
>             7.Update requirements according to production
>             <https://github.com/qgis/qgis-feed/pull/47>
>             8.Add geoip2 in production, setting up log
>             <https://github.com/qgis/qgis-feed/pull/48>
>             9.Use contry code when testing daily_visit.country
>             <https://github.com/qgis/qgis-feed/pull/51>
>             *Still working on:*
>             1.Fresh plugin includes obsolete stuff
>             <https://github.com/qgis/QGIS-Django/issues/46>
>             Changes to the QGIS Feed website are now deployed and
>             available at https://feed.qgis.org.
>             Have a great weekend,
>             Lova
>             Image
>             about open source:
>             * GIS Training
>             *From: *Lova Andriarimalala <lova at kartoza.com>
>             <mailto:lova at kartoza.com>
>             *Date: *Friday, 10 November 2023 at 5:32 PM
>             *Subject: *Re: QGIS Full Stack Web Developer Report
>             Hello everyone,
>             the feed and plugins website development for this week.
>             *PRs open:*
>             10.Add support for renaming plugin name
>             11.Update dockerfile and requirements for production
>             *PR merged:*
>             1.Add web page UI on the root URL
>             <https://github.com/qgis/qgis-feed/pull/43>
>             *Still working on:*
>             2.Deployment of the feed updates
>             Lova
>             Image
>             about open source:
>             * GIS Training
>             *Date: *Friday, 3 November 2023 at 5:05 PM
>             Hello everyone,
>             the feed site development for this week.
>                 *PRs open:*
>                  1. Add web page UI on the root URL
>                 *PR merged:*
>                  1. Using rich editor for content, check data validity
>                     <https://github.com/qgis/qgis-feed/pull/42>
>                 *Still working on:*
>                  1. Some checks and fixes on the entirety
>                     <https://github.com/qgis/qgis-feed/issues/18>
>             Lova
>             Image
>             *QGIS Full Stack Web Developer*
>             about open source:
>             * GIS Training
>             Office: _+261(0)34 09 524 73_
>             *Date: *Friday, 27 October 2023 at 4:53 PM
>             Hello everyone,
>             I'm grateful for your warm welcome, and I'm truly thrilled
>             to join this wonderful community.
>             Here is the report summarizing the progress on the feed
>             *PRs open:*
>                  1. Form submission management
>                     <https://github.com/qgis/qgis-feed/pull/39>
>             *PR merged:*
>                  1. Feeds list page with filter and sorting
>                     <https://github.com/qgis/qgis-feed/pull/30>
>                  2. Feed item form with preview
>                     <https://github.com/qgis/qgis-feed/pull/32>
>                  3. Feed form review step
>                     <https://github.com/qgis/qgis-feed/pull/33>
>                  4. Implement webpack and use it for Bulma CSS
>                     <https://github.com/qgis/qgis-feed/pull/34>
>             *Still working on:*
>                  1. Improve feed item form: Check data validity
>                     <https://github.com/qgis/qgis-feed/issues/25>
>             Lova
>             about open source:
>             * GIS Training
>             *Date: *Friday, 20 October 2023 at 2:54 PM
>             *Subject: *QGIS Full Stack Web Developer Report
>             Hello everyone,
>             Currently, I am working on the website that administers
>             the feeds displayed in the news area of QGIS. The
>             website's repository is available on GitHub:
>             <https://github.com/qgis/qgis-feed>
>             Please find below the report for the past two weeks.
>             *PRs open:*
>             *PR merged:*
>                  1. Create a login page, add test cases, configure GH
>                     actions <https://github.com/qgis/qgis-feed/pull/28>
>             *Still working on:*
>                  1. Use web pack for bulma CSS
>                     <https://github.com/qgis/qgis-feed/issues/29>
>             Please do not hesitate to provide any feedback regarding
>             the report structure or layout. Your suggestions are
>             highly appreciated, as they will enable us to improve the
>             report's quality and readability. Thank you for taking the
>             time to review the report.
>             Lova
>             about open source:
>             * GIS Training
>             _______________________________________________
>             QGIS-Developer mailing list
>             QGIS-Developer at lists.osgeo.org
>             List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>             Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Kartoza Co-Founder
> Visit http://kartoza.com to find out about open source:
> * GIS Training
> Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/0c0af099/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/0c0af099/attachment-0001.jpg>
Type: text/vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231124/0c0af099/attachment-0001.vcf>
More information about the QGIS-Developer mailing list
