[QGIS-Developer] QGIS Full Stack Web Developer Report
Matthias Kuhn matthias at opengis.ch
Sat Nov 25 00:37:44 PST 2023
Thank you very much Lova for working on this application, it's a very
important piece in the QGIS ecosystem!
For the current discussion, I would also suggest making the license
recommended for now and only start enforcing it on a schedule. And I was
wondering if a license field in the metadata.txt would be even better (cmp.
https://python-poetry.org/docs/pyproject/#license), that would be easier to
show on the plugin page?
Is there any way to help prioritizing the issues? I have some wishes that I
would love to see land on the backlog
Kind regards and thanks again for all the good work on this !
Matthias
On Fri, Nov 24, 2023 at 11:49 AM Julien Moura via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Dear Tim,
> Thanks for taking in account my thoughts and make the discussion possible.
> Regarding the second about change management, I totally agree and feel
> really thankful that you make those changes. I can imagine the work it
> represents for your teams maintaining a project like this one. So thank you
> again.
> Regarding your proposal about the license requirements, why not starting
> apply the change management to this? It's a breaking change, even for new
> plugins, right? So, it should be lowered to a non blocking warning,
> documented in PyQGIS cookbook and then deployed as a blocking error in a
> known time windows. This way, in the meanwhile, the plugins ecosystem can
> adapt to new rules (new versions for tools like minimal plugin,
> qgis-plugin-ci, plugin builder...) and make this change more acceptable and
> frictionless.
> Moreover, the rationale behind the required license file into the plugin
> archive is still not solved.
> If you want, I can make a PR to change the warning but I'm pretty sure
> that's not the question here.
> https://github.com/orgs/qgis/projects/6
> Just to let you know this hyperlink leads to a 404 (probably a Github
> rights access setting somewhere).
> Regards
> On 24/11/2023 10:50, Tim Sutton wrote:
> Dear Julien
> Thank you so much for your engagement and suggestions. Fully agreed that
> breaking changes should be well communicated first. So splitting the
> discussion in two:
> 1) License requirements: for now I have chatted with Lova and we propose:
> a) Change the logic such that a license is required for newly registered
> plugins
> b) When updates are made to existing plugins that do not include a
> license, the uploader will be shown a warning indicating that in future the
> license will  be mandatory
> This is already implemented in
> https://github.com/qgis/QGIS-Django/pull/311 and I propose we deploy this
> today / ASAP to address the previously raised issues.
> 2) Change management:
> Yes I think we can introduce more rigour in the process.
> * breaking changes: discuss with the community first, implement, deploy in
> a known time window
> * non-breaking changes: for simple bug fixes, just fix, test and deploy as
> needed
> * non-breaking changes: for features etc. these will be managed on the
> project board here, anyone who wants to be engaged in the process can see
> the planned upcomming work and interact with Lova via the ticket queue.
> * requests to improvements: please file tickets here
> https://github.com/qgis/QGIS-Django/issues
> Regarding a staging site, currently we do not run a staging environment,
> developers have local test environments and I am on the fence as to whether
> there is a lot of value in us maintaining a long running staging site.
> Regards
> Tim
> On Fri, Nov 24, 2023 at 8:08 AM Lova Andriarimalala via QGIS-Developer <
>> Dear Julien,
>> That’s well noted. Thank you.
>> I will add a detailed description in each PR in the future.
>> Regarding the issue of LICENSE file requirements, I totally agree with
>> you. I will also ask Tim if he has suggestions about it.
>> Best regards,
>> Lova
>> [image: Image]
>> *Lova Andriarimalala*
>> *QGIS Full Stack Developer*
>> Visit http://kartoza.com to find out about open source:
>> * Desktop GIS programming services
>> * Geospatial web development
>> * GIS Training
>> * Consulting Services
>> Office: +261(0)34 09 524 73 <+261340952473>
>> *From: *Julien Moura <julien.moura at oslandia.com>
>> *Date: *Friday, 24 November 2023 at 10:47 AM
>> *To: *Lova Andriarimalala <lova at kartoza.com>,
>> qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
>> *Subject: *Re: [QGIS-Developer] QGIS Full Stack Web Developer Report
>> Thanks for your quick reply here Lova,
>> I've no special legibility that my opinion would be greater than yours,
>> so I can't tell if it has to be reverted or not. That's why I ask for
>> discussion before deploying some breaking change, without any warning or
>> information. After having looked to others PR, I would like to see more
>> description about what a PR does exactly, especially when it breaks
>> something.
>> In this case, even after the last PR, this is a breaking and undocumented
>> change. For now, a plugin developer has no way to see that a LICENSE file
>> is now required in its plugin's zip. An error message in a log is not a
>> suitable information, even it's well formulated and clear, especially in
>> the era of automated CI/CD deployments.
>> Regards,
>> Julien
>> On 24/11/2023 08:35, Lova Andriarimalala wrote:
>> Dear Julien,
>> Many thanks for your feedback.
>> In the new PR, the license file is only required for new plugins. For
>> existing plugin updates, it generates just a warning (but doesn't fail)
>> when the license file is missing.
>> However, I'm not sure if we should also just generate a warning for new
>> plugin uploads for now. If so, I will also fix the new plugin upload.
>> Kind regards.
>> [image: Image]
>> * GIS Training
>> *From: *QGIS-Developer <qgis-developer-bounces at lists.osgeo.org>
>> <qgis-developer-bounces at lists.osgeo.org> on behalf of Julien Moura via
>> QGIS-Developer <qgis-developer at lists.osgeo.org>
>> *Date: *Friday, 24 November 2023 at 10:30 AM
>> *To: *qgis-developer at lists.osgeo.org <qgis-developer at lists.osgeo.org>
>> Hello Lova,
>> I cross post my comment to this issue
>> <https://github.com/qgis/QGIS-Django/issues/38#issuecomment-1824010198>
>> related to the PR mentioned below as "Make LICENSE file as required in
>> plugin package <https://github.com/qgis/QGIS-Django/pull/309>", because
>> I did not have any answer there but saw that some changes still have been
>> applied without any comment.
>> While trying to publish or update a plugin, we faced the new error
>> message related to the deployment of this PR
>> <https://github.com/qgis/QGIS-Django/pull/309>:
>> > Fault string: <Fault 1: 'File upload must be a valid QGIS Python plugin
>> compressed archive. Cannot find LICENSE in plugin package.'>
>> See downstream issue on qgis-plugin-ci project (disclaimer: I'm one of
>> the mainteners but speaking on my own here):
>> https://github.com/opengisch/qgis-plugin-ci/issues/255
>> I think this kind of change, which breaks the plugins'publication flow,
>> should be discussed before to be implemented (an issue from 1 person seems
>> to be too light to decide without any discussion), announced to the
>> community, a warning campaign should be run and a transitional phase should
>> be implemented (warning for 6 months, then error). This has a direct impact
>> on hundreds (thousands?) of plugin developers on a community project with
>> several million end users.
>> I understand that this process may seem too cumbersome, and that since
>> the QGIS Django project hasn't been so dynamic for a few years, it's nice
>> to see it get a new lease of life, even if it means merging and deploying
>> on an ongoing basis.
>> As for the underlying principle, I'm generally in favor of strengthening
>> the control mechanisms (automatic or otherwise) for extensions on the
>> official repository, but I think it's really important to do this
>> gradually, or at least to avoid unilateral change "descended from the skies
>> of the developers".
>> Concerning the idea of integrating the license in the plugin package, I'm
>> not really convinced of the interest since most plugins are contaminated by
>> the GPL2+ of QGIS <-- Qt and the license is never displayed to the end
>> user. But why not. After all, it's always a good practice to include
>> licence and spread the word about (re)usage rules.
>> Reverting sounds maybe too rought so I suggest modyfing the behavior to
>> lower the level and make it a simple warning and in the meanwhile starting
>> a communication and preventive work upstream:
>>    1. update documentation:
>>    https://docs.qgis.org/3.28/en/docs/pyqgis_developer_cookbook/plugins/plugins.html
>>    2. communicate on the QGIS Dev list **before** the implementation to
>>    discuss the rationale
>>    3. integrate a warning mechanism
>>    4. manage the QGIS versions concerned (only applicable to new QGIS
>>    released versions after this being merged)
>> A last question: did you have some pre-production environment where to
>> deploy new changes in order to evaluate them before publishing widely? Or
>> some versioning logic, milestone workflow where PRs are grouped before
>> being deployed?
>> Regards,
>> Julien
>> On 17/11/2023 13:59, Lova Andriarimalala via QGIS-Developer wrote:
>> Hello everyone,
>> Please find below the report summarizing the progress on the feed and
>> plugins website development for this week.
>> *PRs open:*
>> 1.       Add support for renaming plugin name
>> <https://github.com/qgis/QGIS-Django/pull/302>
>> 2.       Add command to fix none in search results
>> <https://github.com/qgis/QGIS-Django/pull/304>
>> 3.       Show more records, records items per page
>> <https://github.com/qgis/QGIS-Django/pull/306>
>> 4.       Specify tag page title and other plugin page title
>> <https://github.com/qgis/QGIS-Django/pull/308>
>> 5.       Make LICENSE file as required in plugin package
>> *PR merged:*
>> 6.       Update dockerfile and requirements for production
>> <https://github.com/qgis/qgis-feed/pull/44>
>> 7.       Update requirements according to production
>> <https://github.com/qgis/qgis-feed/pull/47>
>> 8.       Add geoip2 in production, setting up log
>> <https://github.com/qgis/qgis-feed/pull/48>
>> 9.       Use contry code when testing daily_visit.country
>> <https://github.com/qgis/qgis-feed/pull/51>
>> *Still working on:*
>> 1.       Fresh plugin includes obsolete stuff
>> <https://github.com/qgis/QGIS-Django/issues/46>
>> Changes to the QGIS Feed website are now deployed and available at
>> https://feed.qgis.org.
>> Have a great weekend,
>> Lova
>> [image: Image]
>> * GIS Training
>> *From: *Lova Andriarimalala <lova at kartoza.com> <lova at kartoza.com>
>> *Date: *Friday, 10 November 2023 at 5:32 PM
>> *Subject: *Re: QGIS Full Stack Web Developer Report
>> Hello everyone,
>> *PRs open:*
>> 10.    Add support for renaming plugin name
>> 11.    Update dockerfile and requirements for production
>> *PR merged:*
>> 1.       Add web page UI on the root URL
>> <https://github.com/qgis/qgis-feed/pull/43>
>> *Still working on:*
>> 2.       Deployment of the feed updates
>> Lova
>> [image: Image]
>> * GIS Training
>> *Date: *Friday, 3 November 2023 at 5:05 PM
>> Hello everyone,
>> Please find below the report summarizing the progress on the feed site
>> *PRs open:*
>> *PR merged:*
>>    1. Using rich editor for content, check data validity
>>    <https://github.com/qgis/qgis-feed/pull/42>
>> *Still working on:*
>>    1. Some checks and fixes on the entirety
>>    <https://github.com/qgis/qgis-feed/issues/18>
>> Lova
>> [image: Image]
>> *QGIS Full Stack Web Developer*
>> * GIS Training
>> Office: *+261(0)34 09 524 73*
>> *Date: *Friday, 27 October 2023 at 4:53 PM
>> Hello everyone,
>> I'm grateful for your warm welcome, and I'm truly thrilled to join this
>> wonderful community.
>> Here is the report summarizing the progress on the feed site development
>> for this week.
>> *PRs open:*
>>    1. Form submission management
>>       <https://github.com/qgis/qgis-feed/pull/39>
>> *PR merged:*
>>    1. Feeds list page with filter and sorting
>>       <https://github.com/qgis/qgis-feed/pull/30>
>>       2. Feed item form with preview
>>       <https://github.com/qgis/qgis-feed/pull/32>
>>       3. Feed form review step
>>       <https://github.com/qgis/qgis-feed/pull/33>
>>       4. Implement webpack and use it for Bulma CSS
>>       <https://github.com/qgis/qgis-feed/pull/34>
>> *Still working on:*
>>    1. Improve feed item form: Check data validity
>>       <https://github.com/qgis/qgis-feed/issues/25>
>> Lova
>> * GIS Training
>> *Date: *Friday, 20 October 2023 at 2:54 PM
>> *Subject: *QGIS Full Stack Web Developer Report
>> Hello everyone,
>> Currently, I am working on the website that administers the feeds
>> displayed in the news area of QGIS. The website's repository is available
>> on GitHub: https://github.com/qgis/qgis-feed
>> Please find below the report for the past two weeks.
>> *PRs open:*
>> *PR merged:*
>>    1. Create a login page, add test cases, configure GH actions
>>       <https://github.com/qgis/qgis-feed/pull/28>
>> *Still working on:*
>>    1. Use web pack for bulma CSS
>>       <https://github.com/qgis/qgis-feed/issues/29>
>> Please do not hesitate to provide any feedback regarding the report
>> structure or layout. Your suggestions are highly appreciated, as they will
>> enable us to improve the report's quality and readability. Thank you for
>> taking the time to review the report.
>> Lova
>> * GIS Training
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton
> Kartoza Co-Founder
> * GIS Training
> Tim is a member of the QGIS Project Steering Committee
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231125/6b1b953b/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20231125/6b1b953b/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
