[QGIS-Developer] MingW64 Windows 64bit Build action failing: a possible workaround
Sandro Mani manisandro at gmail.com
Fri Sep 15 03:31:37 PDT 2023
>> Mon Sep 11 22:22:12 PDT 2023
>> This should since be fixed in the latest mingw-filesystem. See [1].
> Hi Sandro,
> the new fixed version is now available used, so I will remove my
> workaround.
> Anyway the MingW64 Windows 64bit Build is failing again for: "dnf5:
> command not found".
> The command was changed from dnf to dnf5 1 month ago with
> https://github.com/qgis/QGIS/pull/54152/commits/2a4a4b69475f9ae7d00880a6d3434f723a2a52c1
> because of "dnf: command not found".
> Reverting back to dnf would fix the issue.
> Do you know if it is a temporary issue with dnf5 or should we
> permanently use dnf?
Hi Andrea
I'd revert back to dnf, dnf5 has been postponed for the time being.
Sandro
More information about the QGIS-Developer mailing list
