[QGIS-Developer] QGIS 3D and Graphics Card Requirements
Jean Felder jean.felder at oslandia.com
Thu Sep 21 00:28:07 PDT 2023
Hi Luke,
The higher end card should indeed give you better performance.
However, there is a hard coded limit in QGIS 3D at the moment. A 3D
scene cannot load more than 500 Mo of 3D objects even if you video card
has a lot of available memory when the 3D scene is created.
The idea is to avoid out of memory crashes or GPU hangs. For example, a
lot a 3D scenes could be loaded or other program may consume some gpu ram.
Benoît de Mezzo and I have been trying to remove this limit but the code
is not ready yet.
Cheers,
Jean
Le 20/09/2023 à 23:18, Catania, Luke A ERDC-RDE-GRL-VA CIV via
QGIS-Developer a écrit :
> Anyone out there working with QGIS 3D?
> I am looking to get a new Dell laptop with i9 processor and 64GB
> memory and wondering what the minimum requirements for working with
> QGIS 3D is.  I had a coworker who could not run 3D on his laptop
> assume due to his lower end graphics card.  I don’t offhand know what
> the spec’s on his machine are.
> I am looking at a Dell 7780 or 7680 with either *NVIDIA RTX 5000 Ada
> 16GB GDDR6 video card *or the*RTX 4000 Ada* *12GB GDDR6 video card.*
> Wondering if the higher end card buys me much better performance and
> is worth the hit on battery life.
> Luke
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Jean Felder
Développeur SIG
Oslandia
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230921/6437bcc9/attachment-0001.htm>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230921/6437bcc9/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230921/6437bcc9/attachment-0001.sig>
More information about the QGIS-Developer mailing list
