[Qgis-psc] Vote: QEP #7 - Composer to Layout rename
Anita Graser anitagraser at gmx.at
Fri Nov 14 00:31:11 PST 2014
+0 for a rename for 3.0
because I would also prefer the term "layout" rather than
"composition" but I'm not sure that warrants having to deal with the
consequences, which are mentioned in the proposal.
Anyway, as Jürgen wrote, I'd also like to see UI and API use consistent names.
Best wishes,
Anita
On Thu, Nov 13, 2014 at 10:19 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 13 November 2014 22:24, Anita Graser <anitagraser at gmx.at> wrote:
>> On Thu, Nov 13, 2014 at 11:47 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>>> At this stage I'm just seeking approval for the user visible portion
>>> of the name change.
>> And the name change should happen together with the 3.0 release, right?
> That's the current plan. If the composer rebuild QEP fails, I'll do a
> straight rename for 3.0.
> If the rebuild plan passes then the name change will be introduced by
> the rebuild. This will either happen for 3.0, or possibly be
> introduced earlier in a side-by-side fashion (as was done with the new
> labelling engine, etc). Those implementation details can be discussed
> when I submit the rebuild QEP.
> Nyall
More information about the Qgis-psc mailing list
