[Qgis-psc] Vote: QEP #7 - Composer to Layout rename
Tim Sutton tim at kartoza.com
Sat Nov 15 12:27:12 PST 2014
Hi
On Fri, Nov 14, 2014 at 10:31 AM, Anita Graser <anitagraser at gmx.at> wrote:
> +0 for a rename for 3.0
> because I would also prefer the term "layout" rather than
> "composition" but I'm not sure that warrants having to deal with the
> consequences, which are mentioned in the proposal.
> Anyway, as Jürgen wrote, I'd also like to see UI and API use consistent
> names.
​From my side I guess I'd prefer not to have anything that ​results in us
having side by side implementations and more V2 classes - I think it makes
it very confusing to use the API. Also with regard to the proposed name
changes, I am OK with them in concept but I think it would be better done
in QGIS 3.0 to minimise churn for documentation and training material
authors out there.
So my apologies but for a 2.x release I think I am -1 on the proposed
changes
If you were to amend the proposal to state that changes would be effective
of the 3.0 release it would be +1 from me.
Regards
Tim
> Best wishes,
> Anita
> On Thu, Nov 13, 2014 at 10:19 PM, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
> > On 13 November 2014 22:24, Anita Graser <anitagraser at gmx.at> wrote:
> >> On Thu, Nov 13, 2014 at 11:47 AM, Nyall Dawson <nyall.dawson at gmail.com>
> wrote:
> >>> At this stage I'm just seeking approval for the user visible portion
> >>> of the name change.
> >> And the name change should happen together with the 3.0 release, right?
> > That's the current plan. If the composer rebuild QEP fails, I'll do a
> > straight rename for 3.0.
> > If the rebuild plan passes then the name change will be introduced by
> > the rebuild. This will either happen for 3.0, or possibly be
> > introduced earlier in a side-by-side fashion (as was done with the new
> > labelling engine, etc). Those implementation details can be discussed
> > when I submit the rebuild QEP.
> > Nyall
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-psc
Tim Sutton
Visit http://kartoza.com to find out about open source:
 * Desktop GIS programming services
 * Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20141115/7193a0f4/attachment.html>
More information about the Qgis-psc mailing list
