[Qgis-psc] Finalizing the budget
Andreas Neumann andreas at qgis.org
Wed Dec 13 04:46:32 PST 2023
Hi all,
Thank  you both Ale and Régis for your feedback.
As suggested from Ale, I moved 10k € from the Qt6 migration to the code
reviewing.
We can still try to come up with more formal ways and/or ideas on how to
distribute the 30k € among the active core contributors who want and can
contribute to the code reviewing.
Régis already has formulated some thoughts on the reviewing. We can discuss
this at the next PSC meeting.
Marco: can you please put up the budget proposal for voting among the
voting members - so that we can have an accepted budget when starting into
2024? Thank you!
Greetings,
Andreas
On Wed, 13 Dec 2023 at 09:00, Alessandro Pasotti <apasotti at gmail.com> wrote:
> Hi Andreas,
> I think my proposal probably came at the wrong time, there is no need to
> rush  a decision.
> We can discuss it thoroughly next year.
> But, if we wanted to implement it for 2024, I think that we should
> allocate a budget for at least 4 hours/week.
> We could probably reduce (half?) the budget for QT6 migration because I
> expect that most of the work will be completed with the 2023 budget.
> I would really like to hear what other core devs think about this proposal
> though, I only spoke with a few of them.
> Kind regards
> Il mar 12 dic 2023, 17:48 Andreas Neumann via QGIS-PSC <
> qgis-psc at lists.osgeo.org> ha scritto:
>> Dear PSC colleagues,
>> I'd like to finalize the 2024 budget:
>> The one major issue that needs discussion is the proposal from Ale to
>> have fixed developers with fixed hours to do code and PR reviewing. What
>> do the other PSC members think about this proposal?
>> What is the required budget for this? Currently, we have 20k reserved for
>> this. Is this enough? If not, how much would we need?
>> If we would need more than 20k in the budget - what other budget items
>> could we reduce to get a balanced out budget?
>> See
>> https://docs.google.com/spreadsheets/d/19JlXyiY8KH8gvrERVDGjcA_HWE49GwL42F__HdJnT7I/edit?usp=sharing
>> for the current budget proposal.
>> Thank you for your replies,
>> Andreas
>> Andreas Neumann
>> QGIS.ORG board member (treasurer)
>> QGIS-PSC mailing list
>> QGIS-PSC at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Andreas Neumann
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20231213/a0bfbd8a/attachment.htm>
More information about the QGIS-PSC mailing list
