[Qgis-tr] Italian translaction
Stefano Campus skampus at gmail.com
Wed Sep 16 02:19:33 PDT 2020
ciao werner, thank you for your quick reply.
the problem is that the italian strings in GUI are not present in Tx and
the originals ones have a different and correct translation but they are
not "considered" since a month, while, as you correctly explained, other
strings that have been translated after are now in GUI.
thank you
s.
Il giorno mer 16 set 2020 alle ore 10:37 Werner Macho <
werner.macho at gmail.com> ha scritto:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi!
> Transifex and QGIS are not "directly" connected.
> A change in Transifex does not instantly show up in QGIS GUI.
> The translations first have to be pulled into the release and then
> built - which usually happens with every release.
> So usually you have to wait (at least) for the next point release for
> the translations to show up in the GUI.
> regards
> Werner
> On Wed, Sep 16, 2020 at 10:07 AM Stefano Campus <skampus at gmail.com> wrote:
> > Ciao,
> > the Italian community has finally completed the translation of the whole
> GUI of the three versions of QGIS (LTR, Stable and Dev).
> > however, there are some strange strings that we can't correct.
> > they are the strings that describe the clipping functions in the print
> layout with the atlas that is active.
> > In the italian GUI they are displayed as an old and wrong version, but
> in transifex there is the correct translated version but it is not seen in
> the GUI.
> > how can it be solved?
> > do I have to indicate exactly which strings they are or, now that we are
> at 100%, it can be done a "definitive" synchronization operation ?
> > thank you
> > stefano
> > QGIS-Translators mailing list
> > Qgis-tr at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20200916/1aa4975d/attachment.html>
More information about the Qgis-tr mailing list
