[Qgis-tr] Suggestions available
Werner Macho werner.macho at gmail.com
Mon May 9 02:21:34 PDT 2022
Hi!
Maybe we should do a short online meeting somewhen to decide what to do.
Honestly transifex has changed a lot since we started to use it (well,
development is not a bad thing at all).
Meanwhile there are some other options as well (see GRASS translation).
Maybe it's time for a change? I don't know. But that would be something to
discuss.
regards
Werner
On Mon, May 9, 2022 at 11:17 AM DelazJ <delazj at gmail.com> wrote:
> Transifex Webtranslation page for QGIS is on
> https://www.transifex.com/qgis/
> Hi Stefano, Alexandre
> Strings of the "zzz..." projects are available for the Desktop project
> because some time ago, Alexandre (I assumed he did because of [0]) put the
> projects altogether in what transifex calls a memory group [1]: they do
> share translations each other as suggestions.
> However, by the time we created the project for 3.22 documentation, that
> feature had become a paid one (ref the docs linked above), so that project
> is somehow isolated from the others. If you browse the QGIS Documentation
> project, you will notice that it provides suggestions from itself only.
> None of the other projects is connected to it, so you can't use
> translations you made in Desktop (or Website - though I'm not sure this one
> is connected) project.
> I'm still convinced that we should:
> 1. just drop the zzz projects (at least for 3.4 and 3.10). I'm honestly
> not convinced they are useful to anything today.
> 2. reactivate the zzz 3.16 project, fill it with 3.22 strings (source and
> translations) and rename it into QGIS Documentation. Would that fix
> Stefano's request ? I can't tell without testing because Transifex is a
> closed source project, but if we assume that what are referenced in the
> memory group foreign key is projects ID and not the strings or files of a
> named project, then reusing that project should work IMHO
> 3. Kill the current "QGIS Documentation" as its contents are moved to
> point 2. --> That would mean we have a single project for documentation
> also (along with Website and Desktop), clearer for everyone
> 4. Next time we release a docs project (3.28), we push strings in the
> "QGIS Documentation" project directly instead of creating a new project.
> Why did we not do it the last time? Because the previous experience using
> automated pull/push of Transifex<->github connection has been laborious and
> I was afraid I'd break something. The process is now "well" documented [2]
> with ways to recover if any problem.
> 5. If you are really really afraid that something breaks in 2/3, the
> resurrection and testing can be done in the zzz 3.4 project instead of zzz
> 3.16...
> [0]
> https://lists.osgeo.org/pipermail/qgis-community-team/2022-March/006039.html
> [1] https://docs.transifex.com/translation-memory/sharing-tm
> [2] https://github.com/qgis/QGIS-Documentation#translating
> Regards,
> Harrissou
> Le lun. 9 mai 2022 à 08:16, Alexandre Neto <senhor.neto at gmail.com> a
> écrit :
>> That's something that comes from the  translation memory. If that string
>> have never been translated in the more recent versions it will pick up
>> suggestions from older ones. Which I think it's useful, and allow us to
>> keep some coherence between versions.
>> Don't think there's a way to bump more recent results to the top, other
>> that deleting the old resources permanently.
>> Alexandre Neto
>> A domingo, 8/05/2022, 16:55, Stefano Campus <skampus at gmail.com> escreveu:
>>> Hi, I noticed that while I'm translating in Transifex QGIS Desktop in
>>> the three versions (Master, 3.22 and 3.24), the available suggestions in
>>> the right window come from the desktop versions and from the "zzz OLD QGIS
>>> Documentation".
>>> the translation of the current and active version of the documentation
>>> is not proposed.
>>> How is it possible to make the suggestions of the Documentation project
>>> appear instead of those of the "zzz OLD" project?
>>> https://ibb.co/k9CMXd1
>>> https://ibb.co/SwfPMT6
>>> thank you and ciao!
>>> stefano
>>> QGIS-Translators mailing list
>>> Qgis-tr at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20220509/c1c6e2ee/attachment-0001.htm>
More information about the Qgis-tr mailing list
