[Qgis-user] Still cannot export to MapServer mapfiles (now with Python 2.5.1)
Micha Silver
micha at arava.co.il
Sun Mar 30 08:11:59 PDT 2008
kreshna_iceheart at yahoo.com wrote:
> Thanks, Micha.
> By the way, what version of QuantumGIS do you use?
I tried using 0.9.1 on WinXP, and you're right- the error "Cannot find
ms_export python module" pops up. And the module is indeed in the QGIS
python directory. Tried on two computers, one with QGIS installed with
no_spaces_in_the_path. No luck.
On the other hand, the Mapserver export plugin on Ubuntu, version 0.9.2
works nicely.
The layers in the *.map file are reversed making them display in
mapserver with the top-most layer on top, the same as in QGIS. But
exporting a PostGIS layer still sticks an empty FILTER '' expression.
THis might cause trouble.
So, I suggest you grab the latest 0.9.2 and install it (after removing
the older version). And please report back how the mapserver export
works for you.
Micha Silver
Arava Development Co, Sapir, Israel
tel: +972(8)6592270
cell: +972(52)3665918
