[Qgis-user] Enhancement Requests: Enhanced Map Tips
Andreas Neumann a.neumann at carto.net
Thu Nov 6 12:09:12 PST 2008
Hi Augustin,
Thank you for commenting on the Map Tips enhancement proposal.
I guess your proposal deserves a separate enhancement request because it
may be too different.
But depending how the QGIS developers are trying to solve the map tips
enhancement problem (if they do at all), it may be possible to use the
solution as a base to solve your request further on, too.
Andreas
Agustin Lobo wrote:
> I comment on the one on Enhanced Map Tips.
> I actually would add the ability of
> drawing a simple plot, for example to display
> reflectance values across bands or time series of vegetation
> index "a la Envi".
> Not sure if this should be a different ticket.
> BTW, priority "minor: annoyance or enhancement"
> should not be split in two different categories? I mean that an
> enhancement
> could not be of minor priority, and certainly
> not similar to a minor annoyance.
> Agus
>> Message: 2
>> Date: Thu, 6 Nov 2008 13:58:50 +0100 (CET)
>> From: "Andreas Neumann" <a.neumann at carto.net>
>> Subject: [Qgis-user] Enhancement Requests: Field Support in Print
>>     Composet and Enhanced Map Tips
>> To: "qgis-user" <qgis-user at lists.osgeo.org>
>> Message-ID:
>>     <55301.193.246.86.39.1225976330.squirrel at webmail.customers.iirc.at>
>> Content-Type: text/plain;charset=iso-8859-1
>> Hi QGIS Developers and Users,
>> I just added two enhancement requests:
>> Enhanced Map Tips through Macro Language/Operators
>> (https://trac.osgeo.org/qgis/ticket/1386)
>> and
>> "Field" Support for Print Composer
>> (https://trac.osgeo.org/qgis/ticket/1385)
>> I would like others to comment if these features would be useful and how
>> they could be implemented.
>> I assigned the latter to Marco Hugentobler, since he is working on the
>> print composer.
>> Andreas
>> -- Andreas Neumann Böschacherstrasse 6, CH-8624 Grüt/Gossau,
>> Switzerland Email: a.neumann at carto.net, Web: * http://www.carto.net/
>> (Carto and SVG resources) * http://www.carto.net/neumann/ (personal
>> page) * http://www.svgopen.org/ (SVG Open Conference) *
>> http://www.geofoto.ch/ (Georeferenced Photos of Switzerland)
