[Qgis-user] some problems
ivan marchesini marchesini at unipg.it
Wed Mar 4 04:11:56 PST 2009
Dear Alex,
> > 1) if I try to have a look at table of grass vector layers I can see
> > only the cat column.. not the others columns (both in dbf and postgres)
> I wonder if the attribute table is not attached properly. Have you tried
> v.db.join and specified the table to use with the vector layer?
yes yes I'm a grass user and into grass all is ok... (I suppose you
suggest to verify with v.db.connect)
____________________
v.db.connect -p geologica_or_frane
Vector map <geologica_or_frane at geo_spoleto> is connected by:
layer <1> table <public.geologica_or_frane> in database <geo_spoleto>
through driver <pg> with key <cat>
> Were these layers in grass already or did you import them with QGIS?
the layers were already in grass... I created the map using grass... not
qgis, now I would like to use Qgis only to plot...
> > 2) if I try to split linear feature I obtain a Qgis crash, both using
> > shapefile and postgis layers...
> Could you clarify, are you using the QGIS built in Editing toolbar,
> Split Features command. Does it work on a polygon?
yes, I simply say -> toggle editing and then split features
I have just seen that with polygon it seems to work.... it snaps in two
vertex and the poligon is divided...
but what about breacking a single line?
thanks..
ivan
> Thanks,
> Alex
> Qgis-user mailing list
Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
Preferisco formati liberi.
Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73 at jabber.org
