R: Re: [Qgis-user] manage R behaviour
Borys Jurgiel
borysiasty at aster.pl
Tue Sep 1 02:23:55 PDT 2009
> alessandro.sarretta at inwind.it wrote:
> > Hi Carson,
> > I tried with a simple point layer called "SAMA". Data are loaded
> > correctly, but if I try to use "ls()" or "names(SAMA)" I have no
> > results...
> > If I instead do plot(SAMA$X) I obtain correctly the plot.
> > So data are loaded, it seems a problem with the "print" output on the
> > manageR console....
> > Tell me if I can test something...
> > thanks
> > Ale
That's the same problem I've reported some time ago - no output to console
under windows. Everything else works well.
