R: Re: [Qgis-user] manage R behaviour
Alessandro Sarretta
alessandro.sarretta at inwind.it
Mon Sep 21 09:55:50 PDT 2009
Hi Carson, do you have news about this problem?
For your information, I noticed that using the R console from "SDA4PP"
plugin, I have no problems and I can see variables created form the
console of "manage R" too...
I rememebr you that I'm using QGIS trunk, installed by OSGeo4W in
Windows XP, R2.9.0, manageR 0.7.2
thanks
Ale
alessandro.sarretta at inwind.it ha scritto:
> Hi Carson,
> I tried with a simple point layer called "SAMA". Data are loaded
> correctly, but if I try to use "ls()" or "names(SAMA)" I have no
> results...
> If I instead do plot(SAMA$X) I obtain correctly the plot.
> So data are loaded, it seems a problem with the "print" output on the
> manageR console....
> Tell me if I can test something...
> thanks
> Ale
> ----Messaggio originale----
> Da: carson.farmer at gmail.com
> Data: 26/08/2009 11.10
> A: "Alessandro Sarretta"<alessandro.sarretta at inwind.it>
> Cc: <qgis-user at lists.osgeo.org>
> Ogg: Re: [Qgis-user] manage R behaviour
> Hi guys,
> Does any of the text show up after you load a layer via Ctrl-L or
> anything like that?
> What about if you try to save a graphic (this should export a
> command to the manageR console)?
> Based on the versions of the various software required, I can't
> see why this isn't working.
> It must be a Windows thing, but unfortunately, I don't have access
> to a Windows machine at the moment.
> Cheers,
> Carson
> On Tue, Aug 25, 2009 at 10:12 PM, Alessandro Sarretta
> <mailto:alessandro.sarretta at inwind.it>> wrote:
> Hi Carson,
> same behaviour for me, using QGIS trunk e QGIS 1.1, installed
> by OSGeo4W in Windows XP.
> R2.9.0
> manageR 0.7.2
> qt4-libs 4.5.2-1
> pyqt4 4.5.2-5
> python-rpy2 2.0.3-1
> and congratulations, your plugin is improving really well!
> thanks
> Ale
> Carson Farmer ha scritto:
> Hi Filip,
> Dear all,
> I finally got to work manage R plug-in (version 0.7.2
> woks, I use
> R 2.9.1,
> Qgis 1.0.2, Win XP).
> But I am confused by its behaviour. The console doesn't
> return any
> results.
> I mean, when I type:
> $ x<-1
> $ y<-2
> $ x+y
> Nothing is returned, even though the variables x and y
> exist (they are
> listed on the Environment tab).
> However, when I load a shape file with Ctrl+L, the
> console writes
> out a
> message
> "QGIS Vector Layer
> Is this a standard behaviour of manage R?
> no it is not the standard behaviour... I'm not sure why
> you aren't getting any output to the console with normal R
> commands.
> I haven't testing this plugin on Windows yet, so perhaps
> I'll give this a try tonight and see if I can get the same
> behaviour.
> What versions of Qt and Rpy are you running?
> Carson Farmer
> National Centre for Geocomputation
> John Hume Building,
> National University of Ireland, Maynooth,
> Maynooth,
> Co. Kildare,
> Ireland.
> www.carsonfarmer.com <http://www.carsonfarmer.com>
> Qgis-user mailing list
