[Qgis-user] Announcing ProfileFromLine plugin
Giovanni Manghi giovanni.manghi at gmail.com
Tue Aug 17 04:34:28 PDT 2010
Olá Ricardo,
thanks for the nice tool.
I'm under ubuntu 10.04, using ubuntugis repositories and python-shapely
installed. When I launch the plugin I always get
The shapely python package uses the GEOS library. \Your current version
of GEOS doesn't support the feature needed by Shapely. \Please install a
more recent version of GEOS (version 3.2 or later).
but as a fact I have GEOS 3.2.2 installed...
thanks in advance
-- Giovanni --
On Fri, 2010-08-13 at 21:53 +0100, Ricardo Filipe Soares Garcia da
wrote:
> Hello list
> I have uploaded a new python plugin called ProfileFromLine.
> This plugin will generate points along lines according to a user
> specified interval and will optionally sample loaded raster(s) at each
> new point's location.
> Each new point will keep all the attributes of its originating line,
> plus any raster values that it had been asked to sample. In addition,
> every point will have a distinct attribute and also an attribute that
> stores the distance along its line since the beginning (the line's
> starting point being according to the original digitizing direction).
> the new points layer is created using the 'memory' provider, and the
> user must manually save it to disk. this seemed like a nice option,
> because you can choose your desired format upon saving.
> The plugin depends on the shapely python package, so you must have it
> installed and accessible on your system. This shouldn't be much of a
> problem on linux and windows (it is available on the osgeo4w packages
> as well). since I don't have a Mac I wouldn't know how easy it is to
> get shapely installed, but I trust it to be just as easy ;)
> I hope that it is useful. Please drop me a message through this
> mailing list if you have any suggestions.
