AW: [Qgis-user] Cadtools problem
ludo ludovic.granjon at wanadoo.fr
Wed Jan 13 02:47:27 PST 2010
Thanks for your answer
For the first problem I see tonight at home, I think I set meter
For the second problem, ok I think I don't understand the documentation, It's work perfectly when I select a vertex and after a segment but on the same layer, I understanded that the segment select was on an over layer.
Thanks
Ludovic
> Message du 13/01/10 11:33
> De : "Ziegler Stefan"
> A : "ludo" , qgis-user at lists.osgeo.org
> Copie à :
> Objet : AW: [Qgis-user] Cadtools problem
> Hi Ludovic
> > First, when I try tu use the arc intersection tools on ubuntu 9.10 I never have a result, on
> > windows xp it work perfectly, have you an idea ?
> I developed it on a Ubuntu 9.04 machine so I have no idea... Just a guess: have you set the layer units to feet or meters?
> > Second, when I try to use the Orhtogonal Line, I can select vertex, but when I wan't to select
> > a segment, I can't. An over idea ?
> I had some problems to find a good way to realize this. So the first select snaps to the current layer, the segment selection is snapping to background layers. I'm not sure if I figured out how it really works :) Please set the snapping options of the "segment" layer to the following:
> Mode: to segment
> Tolerance: 30
> Units: pixels
> Be sure it is enabled. Zoom in a bit when you want to select the segment.
> regards
> Stefan
> Thanks
> Ludovic
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100113/44f57d3a/attachment.html>
