[Qgis-user] Mapping landslides
Marco Hugentobler marco at hugis.net
Mon Mar 1 08:28:21 PST 2010
Hi Bob
The units are mm or map units (depending on what you select in the symbol
dialog). So it could be possible to do something like the attached picture.
Maybe it would also be usefull to control the dash offset in some situations
(if the feature start point and dash start point are not supposed to be
identical).
Regards,
Marco
Am Sonntag, 28. Februar 2010 18.16:55 schrieb Bob and Deb:
> Hi Marco,
> I happen to have 1.5 but didn't know it had this functionality.  I
> just tried it and it works great!  What are the units of the number?
> mm?  Would I be able to do something like the attached pic?
> Thanks for your help!
> Bob
> On Sun, Feb 28, 2010 at 3:07 AM, Marco Hugentobler <marco at hugis.net> wrote:
> > Hi Bob
> >>It would be nice if
> >> there was a way to create custom line styles by using a simple
> >> language like "1.5mm line 0.75mm gap"
> > It is possible to use custom line-gap linestyles using the current
> > development version (or wait for 1.5). In the vector properties dialog,
> > go to the symbology tab, click the 'new symbology' button. Then go to
> > 'properties' and check the combo box 'use custom dash pattern'. Select
> > cap style 'Flat' and klick 'change' to insert your custom pattern.
> > Regards,
> > Marco
> > Am Sonntag, 28. Februar 2010 08.21:07 schrieb Bob and Deb:
> >> Luckily the symbols I am interested in are point features.  I just
> >> have to learn more about how to use inkscape.  It would be nice if
> >> language like "1.5mm line 0.75mm gap"  -Bob
> >> On Fri, Feb 26, 2010 at 5:04 PM, Alex Mandel
> >> <tech_dev at wildintellect.com>
> > wrote:
> >> > Inkscape works fine for importing that pdf (And almost any pdf
> >> > assuming it not a rasterized pdf) At most you'll need to select and
> >> > group several pieces into a single object and save it.
> >> > Most of these symbols are actually either very specific in size or are
> >> > line and fill types. Converting to SVG will only help with point
> >> > symbols. In the case of the symbols that are specific in size a png or
> >> > other non scalable graphic might be better to match the rules, SVG
> >> > should also work you'll just have always double check that you've got
> >> > it scaled correctly.
> >> > I know we were working on allowing user created lines and fills but
> >> > I'm not sure how far we've come and know you'll need at least version
> >> > 1.4 to start accessing that ability.
> >> > Thanks,
> >> > Alex
> >> > On 02/26/2010 04:34 PM, Mike Toews wrote:
> >> >> Hi Bob,
> >> >> Sure is possible. First, you need to make the icon into an SVG file.
> >> >> If you have Adobe Illustrator, you can open the PDF you provided a
> >> >> link to, isolate or copy the graphic and save it as SVG. Inkscape is
> >> >> another good (free) tool, but it cannot open PDFs, so you will need
> >> >> to trace the graphic.
> >> >> Once it is an SVG, just place the file into the QGIS svg directory
> >> >> somewhere (e.g., C:\OSGeo4W\apps\qgis-unstable\svg), and it will be
> >> >> available as a point symbol next time you open QGIS. The symbol size
> >> >> can be based on a numeric attribute of the layer by setting
> >> >> Properties
> >> >>> Symbology > Drawing by field > Area scale (the location of this
> >> >> option depends on which version of QGIS, I'm using 1.4.0).
> >> >> -Mike
> >> >> On 26 February 2010 10:31, Bob and Deb <bobdebm at gmail.com> wrote:
> >> >>> Hello all,
> >> >>> I am interested in mapping landslides using the symbols found here:
> >> >>> http://ngmdb.usgs.gov/fgdc_gds/geolsymstd/fgdc-geolsym-sec17.pdf .
> >> >>> Can I do this with qgis?  If I can do this in qgis, I would also
> >> >>> like to have qgis scale some of these symbols so that they are
> >> >>> proportional to the size and direction of the landslide.  How do I
> >> >>> do that?
> >> >>> Thanks in advance!
> >> >>> Bob
> >> _______________________________________________
> >> Qgis-user mailing list
> >> Qgis-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
> > Dr. Marco Hugentobler
> > HUGIS - GIS programming and consulting
> > Webereistr. 66
> > CH-8134 Adliswil
> > marco at hugis.net
> > http://homepage.hispeed.ch/hugis/
> > Technical Advisor QGIS Project Steering Committee
Webereistr. 66
CH-8134 Adliswil
marco at hugis.net
