[Qgis-user] some impressions from my students
Andreas Neumann a.neumann at carto.net
Tue Mar 9 08:40:10 PST 2010
Hi Carlos,
Thank you for your valuable feedback.
Some of the issues you mentioned are already addressed in the newer builds
(1.4 and current trunk).
On Tue, March 9, 2010 4:21 pm, Carlos Grohmann wrote:
> Hello all. I just started teaching a class on GIS for geology
> undergrads. We are using ArcGIS and QGIS.
> My students want to share some impressions from the first two classes:
> Plugin install: it would be really nice to be able to select more than
> one plugin for install, instead of doing it one at a time (what if I
> want them all?)
this is a good suggestion. Not yet available. Maybe the developers could
discuss this in Pisa?
> Identify features: is there a way to identify one feature that's
> partially visible, but the layer is not selected, so I can find out to
> which layer it belongs?
This is already possible. You need to change the behavior:
Options --> MapTools --> Identify Mode --> set to "top down" or "top down,
stop at first" - depending if you want to get all hits or want to stop at
the first hit. You need at least QGIS 1.4 or higher.
> Symbology: Although the classification works fine, changing the color
> for each class is painfull. Can we have color ramps or something like
> it?
I think this is addressed in recent builds and for some while already.
> Translation: (We speak Portuguese). We noticed that in PT-BR version,
> for the Project Properties Dialog, Coordinate Reference System, there
> is a typo.
> it should read "Sistema de Coordenadas Globais" instead of "Sistema de
> Soordenadas Globais" (typed a S instead of a C).
answered by Werner
> I also noticed that when it comes to CRS, we have a long list of
> _datums_, but not of general _projections_. So if I just want to
> change the projection, say from Plate Carré to Mollweide, it's not as
> easy as in Arc, where I can change the projection and the datum.
Good suggestion - I don't know if there are easy fixes for this.
Good to hear that you are using QGIS in teaching! Keep us informed about
progress and problems.
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
