[Qgis-user] Problem on Mac OS X: Saving Point data as a shapefile
Micha Silver micha at arava.co.il
Wed Mar 10 04:35:45 PST 2010
On 03/10/2010 02:17 PM, Erica Donnelly-Swift wrote:
>> So What changed?
> I don't know
>> Maybe try the original Irish Grid 29902 coordinates but remove
>> everything after the decimal point. In other words use integer X-Y
>> values. (You probably don't need precision down to 50 cm. anyway)
> Yes I tried this... but QGIS still crashes.
( cc'ed to the qgis-user list...)
So just to summarize:
You have QGIS 1.4.0 on Mac OSX 10.5.8.
You import a text file with the delimited text plugin and X-Y
coordinates in Lat-Lon, then export to shapefile, choosing EPSG:4326 as
the CRS. This works OK.
Then you import a second text file where the X-Y coords are in the Irish
Grid, and you try to export to a shapefile, choosing the EPSG:29902 CRS
and QGIS crashes.
It that about right?
> On 10 Mar 2010, at 11:34, Micha Silver wrote:
>> On 03/10/2010 12:43 PM, Erica Donnelly-Swift wrote:
>>>> Have you tried with Lon-Lat coordinates in EPSG:4326?
>>> Thanks Micha!!! It works!!
>> So What changed? Maybe try the original Irish Grid 29902 coordinates
>> but remove everything after the decimal point. In other words use
>> integer X-Y values. (You probably don't need precision down to 50 cm.
>> anyway)
>>> On 10 Mar 2010, at 10:32, Micha Silver wrote:
>>>> On 03/10/2010 12:12 PM, Erica Donnelly-Swift wrote:
>>>>> Hi Micha,
>>>>> Thanks for your response,  I have provided a small subset of my
>>>>> data below....  'X' is entered the X field and 'Y' is entered in
>>>>> the Y field when creating a layer from a delimited text file
>>>>> After entering the data I click on "layers"  option and choose
>>>>> "save as shape file" and i click on the Irish Grid reference "ESPG
>>>>> ID 29902". Then QGIS automatically shuts down
>>>> Worked fine for me with QGIS 1.5 on Fedora. Next step I guess is to
>>>> approach William Kyngsburye, http://www.kyngchaos.com/, maintainer
>>>> of the Mac OSX binaries, and ask if he can locate the problem. (I'm
>>>> assuming you installed his frameworks and binaries.)
>>>> Have you tried with Lon-Lat coordinates in EPSG:4326? Do you get
>>>> the same shutdown of QGIS?
>>>>> Record Number,Route,Y,X
>>>>> 54562,4,235289.75,298363.91
>>>>> 54567,4,242287.45,273695.29
>>>>> 54591,4,240706.36,277593.04
>>>>> 54603,4,268483.87,230911.12
>>>>> 54707,4,248367.24,254769.44
>>>>> 55011,4,235016.26,308622.46
>>>>> 55058,4,318101.7,172630
>>>>> 55072,4,264368.56,235140.42
>>>>> 55073,4,268828.35,230494.01
>>>>> 55226,4,234914.83,308904.78
>>>>> 55229,4,235242.19,307630.42
>>>>> 55259,4,235060.93,308406.24
>>>>> 55278,4,245564.1,259476.11
>>>>> 55282,4,330001.05,166989.79
>>>>> 55283,4,320347.41,170992.77
>>>>> 55474,4,284479.03,179568.41
>>>>> 55705,4,325052.42,168305.89
>>>>> 55706,4,328483.64,167241.22
>>>>> 56692,4,317038.33,173459.75
>>>>> 56693,4,318286.25,172475.79
>>>>> 56751,4,248840.76,253815.96
>>>>> 56752,4,245508.53,259549.66
>>>>> 56758,4,268658.12,230704.41
>>>>> On 9 Mar 2010, at 14:03, Micha Silver wrote:
>>>>>> On 09/03/2010 14:06, Erica Donnelly-Swift wrote:
>>>>>>> Hi all,
>>>>>>> I am having difficulty saving point data as a shapefile ....
>>>>>>> QGIS automatically shuts down. The steps I have taken are given
>>>>>>> below. Any advice is greatly appreciated, thanks
>>>>>>> I am working with QGIS version 1.4.0 Enceladus on a Mac OS X
>>>>>>> version 10.5.8
>>>>>>> 1) I created a .csv file from the .xls file, then loaded the .csv
>>>>>>> file into QGIS with the "Add delimited text layer" plugin
>>>>>>> 2)  save the result as a shapefile by clicking on "layers"
>>>>>>> option and choosing "save as shape file" and i click on the
>>>>>>> Irish Grid reference "ESPG ID 29902".
>>>>>>> Then QGIS automatically shuts down.
>>>>>> In order to isolate the problem (Mac OS or the data) would you
>>>>>> mind to supply a subset of your data so we can test on other
>>>>>> platforms?
>>>>>> Micha
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>>>> This mail was received via Mail-SeCure System.
>>>>>> Micha Silver
>>>>>> http://www.surfaces.co.il/
>>>>>> Arava Development Co.  +972-52-3665918
>>>> Micha Silver
>> Micha Silver
Micha Silver
