[Qgis-user] Updated GdalTools
gustavocanale at pop.com.br gustavocanale at pop.com.br
Mon May 17 08:33:54 PDT 2010
forgot to say I am using Mac 10.5
Cheers
Gustavo
> Hi,
> sorry for replying with a different
problem and not a solution,
> but maybe my question is also
relevant to this discussion.
> I am
> trying to learn Qgis
and use it as a platform during my lectures to
> graduate and
undergraduate students about landscape ecology.
> I tried
> to install Home Range_plugin and SDA4PP  and I got the
message:
> rpy2.robjects is missing.
> I tried to install
rpy2 using Python, but
> to I couldn't make it work. As far as I
know, rpy2 is just a plugin to
> make GDAL work in Qgis via R. Is
there a compiled version for GDAL that
> would couple R and Qgis
in a way that this could be used for Home Range
> Analysis as
well?
> Many thanks
> Gustavo
>> I didn't request it directly (just a general
request of plugin
>> developers), but did you add a
configuration option to set the path
> to the
>> GDAL
programs?  Applications (ie QGIS) on OS X don't get
> anything
from the
>> shell environment, like the PATH, and so won't
> find the GDAL programs in
>> the GDAL framework (and on
older
> systems for those that compile a
non-framework GDAL,
> /usr/local/bin is not in the default
PATH).
>> There is
> a hidden mechanism
to add environment variables to applications,
> but
most OSX users won't know about it, and there is no built-in way to
>> configure it (just a 3rd-party pref pane).
>> On
> May 16, 2010, at 3:58 AM, Paolo Cavallini
wrote:
> Hi all.
GdalTools (AKA Raster Tools) as of v.1.1.15 has
> undergone some
major
>>> improvements:
>>> - more than
> a command can be executed simultaneously
>>> - in the
meantime,
> QGIS can still be used (useful for long-running
>>> commands)
>>> - there are 2 more notices for
the user:
>>> . one
> that warns if one is trying to
close a running tool
>>> . one at
> the completion
of the execution
>>> When a long running command
ends, the second message pops up in the
>>> foreground.
>>> https://trac.faunalia.it/GdalTools-plugin/
>>> Thanks
> to Giuseppe for the coding!
>>> Feedback welcome.
> All the
best.
>>> Paolo Cavallini:
http://www.faunalia.it/pc
Qgis-user
> mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
>> William Kyngesburye
<kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
>> "We are at war
with
> them. Neither in hatred nor revenge and with no
>> particular
> pleasure I shall kill every ___ I can
until the war is over.
> That is my duty."
>> "Don't you even hate
> 'em?"
>> "What good would it do if I did? If
> all the many millions of people of the
>> allied nations
devoted an
> entire year exclusively to hating the ____ it
>> wouldn't kill one
> ___ nor shorten the war one
day."
>> <Ha, ha>
> "And
it might give 'em all stomach ulcers."
> - Tarzan, on war
>> Qgis-user
> mailing list
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100517/71a6f696/attachment.html>
