[Qgis-user] ECW support on Ubuntu
Micha Silver micha at arava.co.il
Wed May 19 12:10:20 PDT 2010
For ubunteros using the UbuntuGIS repository who require ECW support:
I noticed that the latest update bumps gdal to 1.7.2 and you then loose
ECW. Here's how to get it back:
After an update check the gdal version:
gdalinfo --version
GDAL 1.7.2, released 2010/04/23
Now check for ecw:
gdalinfo --formats | grep -i ecw
(returns nothing, indicating that ECW is gone)
So:
sudo apt-get purge gdal-ecw-src  # get rid of the old source pkg
sudo apt-get autoremove
sudo apt-get install libgdal-ecw-src  # Add the source pkg for gdal 1.7
Next, I'm assuming that the libecw SDK is already installed on your
system. The includes and libs, by default, are installed under
/usr/local, so:
sudo gdal-ecw-build /usr/local/   # build the new gdal-ecw plugin
sudo ldconfig
  ECW (rw): ERMapper Compressed Wavelets
  JP2ECW (rw+): ERMapper JPEG2000
and you're back in business.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
