[Qgis-user] Making QGIS Project Directory Independent?
Ramon AndiƱach custard at westnet.com.au
Mon Sep 26 18:16:26 PDT 2011
On 27/09/2011, at 8:20, "Bruce, Bob (CON)" <Bob.Bruce at gov.mb.ca> wrote:
> Does anyone know how I can remove the directory path from layers in a QGIS project and have QGIS find the files for a project in the same folder as the project file?
> I would like to distribute projects to end users and not have them prompted for the file locations if the data files are in the same folder as the project file but that folder is not in the original location that is was when the project was created.
> Thanks,
>             Bob Bruce
If everything is in a fixed relative position to the project file, then you could set the save paths project property in the general tab to relative.
Should be ideal for this task.
-ramon.
