[Qgis-user] Georeferencer bug 3743 fix?
William Kyngesburye woklist at kyngchaos.com
Tue Apr 3 18:07:09 PDT 2012
Does the workaround in the bug report work for you?  Basically, windows are hiding windows, so it seems like something is broken.  Resize and move windows around so you can see them all, then you should be able to get it working.
I guess the bug is really now that Map Coordinates window appears behind other windows, instead of popping to front.
On Apr 3, 2012, at 7:15 PM, Advrk Aplmrkt wrote:
> Hello,
> I tried running QGIS versions 1.7.4, 1.8, and 1.9 (revision e13e45f)
> with builds from KyngChaos website
> (http://www.kyngchaos.com/software/qgis) on Mac OS X 10.6.8.
> For all versions a major problem with the georeferencer remains (QGIS
> bug #3743 http://hub.qgis.org/issues/3743): you can't set the map
> coordinates from the canvas.
> This bug has been there for more than a year, and is a killer bug for me.
> Two questions:
> (1) Is this bug on a todo list to be fixed in an upcoming version? If
> so, which version? I have literally been waiting for more than year
> for this to be fixed.
> (2) The georeferencer window used to have a panel listing the points
> you picked for georeferencing, but it is not there anymore. How do I
> get it back?
> Thank you very much for your help.
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
"I ache, therefore I am.  Or in my case - I am, therefore I ache."
- Marvin
