[Qgis-user] Further on composer problems [1/2]
Ramon AndiƱach
custard at westnet.com.au
Thu Aug 2 20:17:04 PDT 2012
A guess.
The x and y parameters are in "map units" or the project's projection.
So if you have a large scale, in a projected CRS, then QGIS will try and draw a grid line in every three feet/meters. Very time consuming.
-ramon.
On 03/08/2012, at 11:08, Chandra Shekhar Balachandran <csbalachandran at gmail.com> wrote:
> Following Tim Sutton's email, I am adding a little more descriptin of what has been happening. Separately i will share the actual shape files. Attaching both into one message went over the size limit.
> I was not sure if attachments would be ok or not. Upon Tim Sutton's suggestion, I am attaching the actual data files and clarifying my situation further, below.
> In the mac, in the composer where I start setting grid parameters,
> i select to display grid,
> then the grid type (i select crosses) -- actually i am trying to get only tics on the edges with nothing on the map (crosses or full lines), but of the options available, crosses are my choice
> then i come to "Interval X" and enter a value, say 2 or 3
> next, I come to "Interval Y" and enter the same value
> and then the system hangs; often i can't even enter the Y value because the system hangs as soon as i put the cursor in the field.
> i tried doing things in different order after selecting 'grid' -- thinking it may be some kind of quirk in my installation that i can work around. invariably, the 2nd or 3rd step after selecting 'grid' causes the machine to hang.
> In the PC, i had already tried right-clicking on the blank space to get back the item properties box, but it hadn't worked. Hence my question in the posting.
> Thanks.
> CSB
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120803/bf7e6d7e/attachment.html>
