[Qgis-user] Further on composer problems [1/2]
Chandra Shekhar Balachandran
csbalachandran at gmail.com
Fri Aug 3 08:15:37 PDT 2012
> Date: Fri, 3 Aug 2012 11:17:04 +0800
> From: Ramon Andi?ach <custard at westnet.com.au>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Further on composer problems [1/2]
> Message-ID: <9A139266-B249-4BF6-BFA1-B4453DC88820 at westnet.com.au>
> Content-Type: text/plain; charset="us-ascii"
> A guess.
> The x and y parameters are in "map units" or the project's projection.
> So if you have a large scale, in a projected CRS, then QGIS will try and
> draw a grid line in every three feet/meters. Very time consuming.
> -ramon.
Ramon, thanks for your help. I set the numbers for the X and Y as 250000
and it worked. Tnen, I was able to get the scale bar correctly in Km.
But I have another problem now. The grid shown is in the map units set at
250000 instead of Lat/Long. I need a grid that shows Lat/Long instead of
metres. Could you suggest how I might do that?
Thanks again.
CSB
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120803/61875184/attachment.html>
