[Qgis-user] XYtools needs Excel python modules
Healthmaps
rhoskins at u.washington.edu
Mon Aug 13 00:24:08 PDT 2012
But if one loads XYtools and then has to go back to the OSGEO4 download process again to get the missing modules then couldn't the OSGEO4 download process be set up to download those modules in the first place? All I had to do was use the advanced install and check two modules from a list that had not already been installed where as many others on that list already had been and were set up as some general install. I sort of understood what you wrote, but I guess not quite.
Best,
Richard
Anchorage, AK
On Mon, 13 Aug 2012, Andre Joost [via OSGeo.org] wrote:
> Am 13.08.12 08:42, schrieb Healthmaps: > indeed, I have learned this the hard way! It does seems that these > modules could be loaded
> when the Plugin is loaded but perhaps there > is some reasonable, technical reason why that is not done. Thanks - > The reason is that
> Qgis sets its own environment variables and does not care about any other software installed on the PC. That has the advantage that it
> does not spoil any other installed program, which might depend on other versions of python, gdal or wahtever. Only Microsoft VC++
> runtime does not fit into this concept. Greetings, Andr?? Joost _______________________________________________ Qgis-user mailing list
> [hidden email] http://lists.osgeo.org/mailman/listinfo/qgis-user
> _______________________________________________________________________________________________________________________________________
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.n6.nabble.com/XYtools-needs-Excel-python-modules-tp4994635p4994746.html
> To unsubscribe from XYtools needs Excel python modules, click here. NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/XYtools-needs-Excel-python-modules-tp4994635p4994749.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20120813/87d8760c/attachment.html>
